It is currently Sat Apr 27, 2024 1:56 am
PostPosted: Wed Jun 25, 2003 9:16 pm
89Colt/Mirage Mas wire colors 1.6L turbo
pin 1 Idle Postion Switch........Blue
pin 2 air flow sensor..............Green/Blue stripe
pin 3 MPI control...................Red
pin 4 5v Power supply...........Green/Red stripe
pin 5 not used.......................N/A
pin 6 Ground for sensors........Green/Black stripe
pin 7 Baro. pressure sensor....Green/Yellow stripe
pin 8 Intake temp sensor........Green/Orange stripe
Colt/Mirage Mas pin order
.....4.....3....2....1....
.....8.....7....6....X....
pin 5=X not used
98 DSM wire colors 2.0L turbo
pin 1 5 volt power supply........Green/Yellow stripe
pin 2 Baro. pressure sensor.....Orange
pin 3 Airflow sensor.................Blue/Yellow stripe
pin 4 MPI................................Red
pin 5 Ground for sensors..........Black
pin 6 Intake temp sensor.........Red/Blue stripe
pin 7 Idle position....................Red/White stripe
pin 8 Not Used.........................N/A
2g Mas pin order
...1...2...3...4...5...6...7...X....
pin 8=X not used
So to summarize:
4g61 pins ---------- 2G MAF
pin 1 ---------------- Pin 7
pin 2 ---------------- pin 3
pin 3 ---------------- pin 4
pin 4 ---------------- pin 1
pin 5 ---------------- x
pin 6 ---------------- pin 5
pin 7 ---------------- pin 2
pin 8 ---------------- pin 6
Match up the 2 pins that correspond to one another.
I removed the female part from the 1g Mas so I wouldnt have to cut my wiring harness.I found this to be the easiest way.Soldering the wires to the plug then heat shrink terminals on the female plug followed by wire loom to keep it all neat looking.
Hope this helps someone please feel free to correct or add anything :D
94 Mirage Project underway...
