It is currently Tue Oct 21, 2025 7:35 am
PostPosted: Wed Jan 05, 2022 2:29 pm
Any one of you have replace the 4g61 head on to 4g63t after you got knock issue?? I have phantom knock issue i read 43 on datalogger pls help me i can not handle of this issue and car is retaring all the time but sometimes not.. i can share datalogger values if you need them
thank you🙏
PostPosted: Sat Jan 08, 2022 10:54 am
What is your exact setup?
High knock can be caused by a faulty knock sensor.
PostPosted: Wed Mar 23, 2022 11:10 pm
With the 4G 61 head on the 63 block you probably got about 11 or 12:1 compression that’s the problem.
PostPosted: Wed Feb 26, 2025 3:17 pm
Higher compression, using low octane fuel, faulty knock sensor that no longer has the goo in place, ignition timing too far advanced.
