It is currently Mon Oct 20, 2025 5:36 am
 Post subject: New PB- 9.9@155
PostPosted: Sat May 26, 2018 11:43 am
Surprising day at Test and Tune yesterday. With the Gt42, if you miss a shift the pass is effectively over. Since it didn't want to shift into second over 7500, I decided to try short shifting 2nd gear to get it in and was surprised with the result!
Short shifting the car caused it to take 5.2 seconds from launch to see 30+psi
https://www.youtube.com/watch?v=TBb7oC7XCvo
Lots of room for improvement basically everywhere. As it stands, it would probably go faster with the smaller turbo as the car sits. Would have been really interesting to see what the 67mm would have done with the 26's
More to come.
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
 Post subject: Re: New PB- 9.9@155
PostPosted: Fri Jun 01, 2018 5:32 am
Congrats on the 9.9!
PostPosted: Mon Jun 11, 2018 6:14 am
Well done! that fair moving!
PostPosted: Tue Jun 12, 2018 6:26 pm
Tis fast the El Chapo!
PostPosted: Sun Jun 24, 2018 11:07 am
Bump for 9.7@157 and 865 whp Dyno @ Carlyle Racing for SCT!
https://www.youtube.com/watch?v=HuaZfOJDZVE
9.7 pass. Easy 1.7 60ft.
https://www.youtube.com/watch?v=AXzYBqshiaM
Dyno- Made 865 AWHP
Current
08 535ix 420awhp
PostPosted: Tue Jul 03, 2018 12:42 pm
Thumbs up JP!!! Car is moving out!!! Looking forward to checking it out in August.
91 Colt GL "dandelion demon"
PostPosted: Mon Jul 09, 2018 9:55 pm
It will be good to see you! Test rides available :)
In the last few weeks, I wired in a BCS so I can add duty cycle though link to help keep the boost up top. While out testing the new controler, I lost my clutch pedal. Had to limp home rev matching!
Hydraulics checked out. Ended up being a broken pressure plate. Found a "bad twin" on craigslist I made work with some "creative adjustments" lol. More on that later.
So-went to a local import day at the track. same boost as last time out, just some duty cycle up top in 2nd, 3rd, 4th. It was HOT. about 90 deg.
Leave easy 1.7 60- have my BEST 1/8th mph 122- it holding boost..things look good- then BAG. Torquesteer?? Shifted 4th and kept on rollin' Went another 9.7x whis is remarkable considering I GRENADED my T case- in 3rd gear! LOL
I pulled the T case and Driveshaft and was prepared to race in FWD, but a full oil down delayed things long enough that packed up and kept drinking beer.
We had fun, and she drove into the garage under its own power, so no complaints here! Doubt I will be out again before the shootout since I have such a hectic work schedule next month.
Current
08 535ix 420awhp
