It is currently Thu Oct 23, 2025 4:00 am
 Post subject: Project Low Buck Laser
PostPosted: Sun Apr 20, 2014 5:05 pm
So back about 2 years ago I bought myself a horrible birthday present. A 1992 Plymouth Laser RS AWD. This thing is THE DSM to have, its the rarest of all of them, lightest, being manual windows, no cruise, and still AWD. The car came with the bigger stock brakes, the best transmission (for a first gen), the 6 bolt engine (no crank walk), and the 4 bolt rear end, which is almost bullet proof. It was doomed to sit for many months because I didn't need it, or another project at the time, was working on my truck swap... moved all my projects to my new house (except it). Life went on and I finally brought it over. Thinking it might be an easy fix because I needed some money, it turned out very bad... here is the story...
Here it is moments after I bought it. Dec 18 of 2012
Check out that sweet no rear window, and the busted windshield. You can imagine how awesome the interior was.
Sept 2 2013 I decided to bring it to my house. I gave it a bath at the car wash on the way over.
I could tell the car had jumped time, but i figured it couldn't be too bad. Worse I'd ever seen was 1 piston killed. When I pulled the head, I was prepared for what I found. 3/4 were DOA, the block would need bored if I was going to use it. I lost interest, and it sat a while longer.
I had went back and forward on fixing it or parting it out. I could use all the bits to AWD the Mirage, but I've been daily driving it for so long, not sure I could give it up for long enough to due that. So it sat some more. In January I decided to pull the engine and see what might be good. If I was going to part it out, I'd have to pull it anyway.
I decided to throw an engine together, as cheap as I could. I had a stock block and head laying around. I yanked the crank out of the original engine, as well as the oil pump, front case and what ever bits I could salvage that weren't damaged. A friend sent me a set of used stock pistons (we aren't sure but they may be Na pistons, so more compression.) I had 90% of everything I needed.
While driving the balance shaft delete seal in, the front case broke. That's ok JB weld and an aluminum plate to the rescue.
The interior was so bad, this is all that was worth keeping.
The car had no keys and the lock mechanism was gone from the column. I went race car on this one. Also made a gauge holder for some misc gauges I had laying around.
The engine pieced together, ready to go back in.
Sitting back in.
While I had the front end apart installing an oil cooler I had to go a little redneck. I had this set of air horns that came off a car I had bought and parted out. I even polished the head lights.
This is how it sits now, I'm waiting on some parts I need for the timing assembly. I have some really fun plans for this car. I don't want to give the idea away just yet though!
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Apr 20, 2014 5:54 pm
Glad to see you saved it. Turbo DSM's seem to be getting more rare.
PostPosted: Sun Apr 20, 2014 7:20 pm
Nice to see you finally doing something with this thing. I have to disagree about this being "the DSM to have", because it's easily the ugliest DSM ever made, and you can easily swap all those more desirable parts onto a better-looking car. :tonqe:
PostPosted: Sun Apr 20, 2014 7:49 pm
It's argued that this is the lightest car to have, because it has less plastic than the others :P
I like the laser, but its the sleeper in me.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Apr 20, 2014 8:02 pm
That'd be the one I'd get, I don't live in cali so I don't care what it looks like. :lol:
PostPosted: Sun Apr 20, 2014 11:51 pm
Lighter by what, 20 pounds? :ANAL:
PostPosted: Mon Apr 21, 2014 4:18 am
I bet you've never taken anything out at the track to shave 20 lbs. :P
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Mon Apr 21, 2014 9:25 am
Maybe when I was a kid, but not recently. I run it how I brung it. :wink:
PostPosted: Mon Apr 21, 2014 5:39 pm
I know the plans for the car!!!! :twisted: It's exactly what I have been wanting to do with a dsm for a long time.
PostPosted: Fri Apr 25, 2014 7:56 pm
Picked up some cheap coil over sleeves. Was going to install them, but the shocks are so far gone, I couldn't make myself put them back on. Quick run to rockauto.com, got some KYB GR2's and some other bits on the way.
They are running a $40 rebate on KYB's, if you order 4, fill out the paperwork and they will mail you a check for $40. So now its a waiting game on the suspension...
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Apr 26, 2014 12:11 am
That engine is in the same shape that the engine in my first dsm was in. Which also happened to be a 92 laser rs awd.
Mine had power windows, but was almost200lbs lighter than my 92 talon awd. I could not explain the difference in weight. But am still a sucker for lasers.
PostPosted: Sat Apr 26, 2014 8:53 am
See Tony... Laser = Lighter :)
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Apr 27, 2014 7:21 pm
That is very surprising. I wonder where the weight went?
PostPosted: Sun Apr 27, 2014 10:43 pm
I dont know. Stuff had been done to the car, but nothig was obvious, even had carpet padding and all that.
It didnt have the super adjustable seats that the talon did. And all accessories worked.
But it tickled the scales close to 2950 and the talon was closer to 3200, but i dont remember fuel levels.
PostPosted: Mon Apr 28, 2014 1:38 am
The only adjustment I've had on any of my seats was for lumbar support.
