It is currently Sun Nov 02, 2025 3:43 am
 Post subject: Carpet and Data logging
PostPosted: Fri Sep 27, 2013 6:38 pm
I have a couple of random questions that are totally unrelated.
What other year/model of car would have the same carpet as a 92 Plymouth Colt? I would assume 89-92 Mirages and Colts would be the same but it seems like anyone who sells aftermarket carpet skips over this year for the Colt.
I have used TMOLog and Tuner Pro RT on my 91 Vista with mixed results. TMOLog works fine but does not seem as robust as Tuner Pro RT. Tuner Pro RT works but some of the sensor data is a bit off (CLT & IAT) and I cannot link the tables to make the data acquisition tracing work. Has anyone had any luck with this?
PostPosted: Fri Sep 27, 2013 7:27 pm
You may need to register, but this is the best link going for logging with TP :).
http://forum.dsmecu.com/viewtopic.php?id=657
PostPosted: Sat Sep 28, 2013 6:07 am
Thanks for the info. I'm guessing the xdf that I'm using is not totally correct with it showing the temperatures way high.
PostPosted: Sat Sep 28, 2013 6:46 pm
89-92 Mirage Colt Summit hatch or Sedan, you may have two options and two different lengths if the floor pan is any longer for the sedan. Watch out for MiniVan style Summits.
I bought a carpet that had been purchased from ACC carpets. They were rumored to not have anymore left, but that was some time ago. Call and ask, worst they say is no.
PostPosted: Sat Sep 28, 2013 7:04 pm
I have a 92 hatch and can find carpet for a 91 hatch. I'm assuming it should fit.
PostPosted: Sat Sep 28, 2013 7:53 pm
Yes, 89-92 should be identical. You likely have to make the holes for the seats, seat belts, console/shifter base, etc. They were all the same in this regard. Just make sure the company knows that it isn't a Minivan style. 200, GT or not GT, but not minivan Summit/Colt.
