It is currently Fri Oct 24, 2025 2:18 am
PostPosted: Wed Jun 26, 2013 6:55 am
Ok guys, I've been trying to find a replacement trans for a bit. Shaun has a F5M22 from a 1g DSM non turbo, and I know it will bolt up.
But 1. will I need to use a different flywheel? Or is the 4G15 fine to reach the starter.
2. Will my Colt 1.5 CVs fit trans to frame distance? Or will I need a certain combo of CSM/DSM CV?
1991 Dodge Colt - 1.5L 4G15 - Swap Project
1989 Dodge Colt GT - 2.0 4G63T - Racecar
1995 Honda Prelude - H23A2 - DD
PostPosted: Thu Jun 27, 2013 2:57 am
Grab the 1g non turbo flywheel & clutch assembly for this, I believe the starter plate (between block and trans) you will need also. Perfect fitment with 1.5 Colt axles.
Good stuff - trucks bring it!
PostPosted: Thu Jun 27, 2013 6:30 pm
So, if I bolt the flywheel up, order a new clutch set for a 1g, everything should work out perfect? And I thought the starter plate was just a dust shield?
Thanks for the reply man. Looks like I can finally have one of the Colts back up. :P
PostPosted: Fri Jun 28, 2013 6:27 am
The starter plate lines up the starter and mounts it properly, you must have the correct starter plate for the transmission or you will not be starting the car.
Thom
PostPosted: Fri Jun 28, 2013 3:35 pm
Yes, so long as it is a N/A 1g FWD flywheel.
PostPosted: Fri Jun 28, 2013 6:29 pm
Copy on that starter plate, I don't think he is sending a starter plate attached or with, so I'll have to source one out of a N/A 1g, right?
And he is sending a lightened flywheel for an NA 1g so Im good there.
You guys are awesome. Thanks.
PostPosted: Sat Jun 29, 2013 3:49 am
Yeah, and I believe you could even use a 1g turbo fwd starter plate as well.
PostPosted: Sun Jun 30, 2013 10:56 pm
I'm not sure if it matters for the starter plate, but the 1g turbo bellhousing is bigger than a non turbo bellhousing. So if you use it I'm not sure it would work...
Someone else on here may have more info/input on that though.
