It is currently Mon Oct 27, 2025 11:09 pm
PostPosted: Sun Mar 18, 2012 10:19 pm
2 1G cylinder heads- $100 shipped for the runner, $75 shipped for the other
1 was a runner, but could use a going through
The other needs some work but has a flat surface. It has two exhaust stud holes that are messed up. One needs welded and retapped, the other needs a time sert installed.
Blown 14b center cartridge with actuator-$40 shipped
Clutch Masters full face clutch disc, used but runable-$40 shipped
G32B/4G37 flywheel-$30 shipped
14b compressor housing-$20 shipped
3" 2G AWD exhaust- it was modified(hammered) to fit a FWD chassis, but still bolts up and works on both. It has an Apexi muffler on it-$150(prefer local pick up)
2 T25 exhaust housings-$20 shipped each
2 Hyundai valve covers- One black studded one, One aluminum colored one-$50 shipped/obo
7 bolt lower timing cover-$30 shipped
1G fuel rail-$20 shipped
7 bolt stock AWD flywheel-$40 shipped
1G auto AWD transfer case-$150 shipped
2G auto AWD transmission-unknown condition inside-$300/obo shipped
G4CS(6 bolt) block and crank-will not separate, still currently a running short block-$250/obo shipped
Pics in the link below
http://smg.photobucket.com/albums/v739/ ... e%20stuff/
Most prices firm unless listed otherwise. But if you need it let me know.
Steven Johnson
303-681-4575
paypal address-
biglady112@yahoo.com
1985 Mitsubishi Cordia
Build in progress
