It is currently Tue Oct 28, 2025 2:58 am
PostPosted: Fri Mar 16, 2012 6:27 pm
I've bought I turbo this week.
Today I get it.
It's a TE04H Turbo.
Is it possible to use this turbo for a 4G63?
I searched via google, I only know the turbo are in 2,5L engines...
Does somebody use this turbo?
Sorry, but with turbos I've got no experience.
http://www.facebook.com/c58.org
PostPosted: Fri Mar 16, 2012 11:30 pm
I don't know very much about these turbos, but I'm guessing the center-section of this turbo is different than the TD04 and/or TD05 turbos that come on 4g61/4g63's. This matters because the center-section is where all your oil and water lines hook up. I also have no idea if the flanges are correct to bolt up to a 4g63. Post up a picture of it, if you can.
PostPosted: Sat Mar 17, 2012 6:57 am
sorry, of course, here the pics.
PostPosted: Sat Mar 17, 2012 7:18 am
It looks like a turbo for subaru? I may be wrong..
PostPosted: Sat Mar 17, 2012 3:36 pm
CSM O.G.
That flange is k-car/omni style (also confirmed by the chrysler badge on it), its very close to T3 but with one bolt moved further out. If I recall from the early days of turbocharging random stuff (circa 2002 around here) you CAN redrill the hole closer in and use a T3-flanged manifold. THe problem is that these are really small turbos that never put out much boost, which is why they were used primarily on D-series ghetto-fab Hondas. (see: www.homemadeturbo.com back in the day).
Will it run on your motor? sure. Will it be right for it? no.
Hope that helps
~Joe
PostPosted: Sat Mar 17, 2012 3:42 pm
Yeah, this would be very difficult to adapt to a 4g63, and definitely not worth the time or the effort.
PostPosted: Sat Mar 17, 2012 4:53 pm
Hm, ok, now I know why I get it so cheap from a CSM owner :-?
Thanks for your answers!
Other questions btw.
Where can I see on a td05h turbo if it's a 14b or 16g or something else?
sorry for the noob question.
PostPosted: Sat Mar 17, 2012 5:47 pm
Look here for pictures : http://www.4g61t.org/forum/viewtopic.php?f=6&t=33399
Also for the part number stamped on the compressor housing :
14B
49178-01010
49178-01030
49178-01400
49178-01410
Small 16G
49178-01520
49178-05200
Big 16G
49178-01420
Evo I Big 16G
49178-01450
Evo II Big 16G
49178-01460
Evo III Big 16G
49178-01470
PostPosted: Sat Mar 17, 2012 6:01 pm
CSM O.G.
see where yours says TE04H? a TD05 will be in the same general area.
PostPosted: Sat Mar 17, 2012 6:02 pm
Ok, thanks a lot!
