Why do you need LSD's?
All DSM AWD transmissions have an viscous LSD center diff from the factory, and most of them had a viscous LSD in the rear diff as well (3 bolt and 4 bolt), unless it's a GVR4 diff that you're using. The only open diff is the front, and most people have no issue with this.
_________________ 91 GSX - 511fwhp and 352 lb/ft 25psi 110 octane, 7.68 @ 95.9mph 1/8th 21psi 91 octane, 11.93 @ 112.9mph, 117.7mph best trap speed, 20psi 91 octane
