It is currently Tue Oct 21, 2025 6:40 pm
PostPosted: Fri Nov 04, 2011 8:19 am
Negative Nancy
That last 2 timing belts i have installed have been by getting the timing belt marks lined up and then rolling the belt onto the top cam gear sorta like putting a bike chain on.. There is not a lot of room between the block and shock tower as you know. Any tips or instructions? Does it unbolt or swing out of the way?
PostPosted: Fri Nov 04, 2011 10:09 am
Insert timing belt tensioner tool
Loosen timing belt tensioner pulley
1990 Colt AWD 8.8
PostPosted: Fri Nov 04, 2011 1:25 pm
Is this on a DOHC or SOHC engine?
PostPosted: Fri Nov 04, 2011 4:28 pm
1.5's have a spring tensioner.
PostPosted: Sat Nov 05, 2011 12:19 am
Didn't realize what forum this was in.. my post was regarding a 4g63 :( sowwy
1990 Colt AWD 8.8
PostPosted: Sat Nov 05, 2011 11:07 am
Have you checked out the factory manual yet?
PostPosted: Sat Nov 05, 2011 11:17 am
Negative Nancy
Dont have one. Had one with my colt and mirage, but not summit. On the last 1.5 I started to loosen the bolt, but then retightened as I didnt want anything to fall apart due to the lack of room I had to work with.
PostPosted: Sat Nov 05, 2011 2:21 pm
All the FSMs are available on Jason's site.
