It is currently Tue Oct 28, 2025 12:02 am
 Post subject: Blowing gearboxes..
PostPosted: Thu May 26, 2011 6:13 pm
Just wanted to put up a quick thread asking if any body else has trouble with 4g61t gearboxes? Is it a common problem for them to blow, i've been through two in under two months? :(
 Post subject: Re: Blowing gearboxes..
PostPosted: Thu May 26, 2011 6:18 pm
Stock engine?
PostPosted: Thu May 26, 2011 6:19 pm
The stock transmission mated to a 4g61t motor is the KM210 tranny. Are you at or around stock power level, and under what condition did the transmissions go out on you?
Good stuff - trucks bring it!
PostPosted: Thu May 26, 2011 6:35 pm
Short answer: yes
PostPosted: Thu May 26, 2011 7:17 pm
Weren't some 1.6L engine in other markets (Asia/JDM) matted to KM206 tranny's? I ran a sonata km210 last year on a 2L with a gt30 turbo, never had any issues, but I never launched the car either.
PostPosted: Thu May 26, 2011 8:37 pm
I grenaded a shep rebuilt km210. It was neato
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu May 26, 2011 8:50 pm
I've only broken the 3rd gear shift fork on mine, and I've beat the shit out of it...not sure what you guys are doing :)
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Thu May 26, 2011 10:27 pm
Digital Baby Troll
I generally just blow Trannys.
89 Mirage Turbo-Money pit
99 Jeep Cherokee-1/4 Epic
01 Cobra-Too Thirsty
72 Dodge-Pedo'van
PostPosted: Fri May 27, 2011 7:52 am
Remind me what corner your picking them up at so I dont have that problem too. Should be the other way around! :lol:
PostPosted: Fri May 27, 2011 8:50 am
My Summit LX sedan has a KM206 in it.
PostPosted: Tue May 31, 2011 12:45 pm
Yea. recieving a blow is borderline ok, especially if you didnt know, but knowingly blowing trannies is very homosexual
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Sun Jun 05, 2011 6:19 pm
I am around stock power, maybe slightly higher, I have raised the boost pressure slightly but that is about it, ive blown two of them in under 4months. i live in newzealand so it is a jap import? maybe slightly different to the mirages you guys get over in the states? maybe its just my driving style?
PostPosted: Sun Jun 05, 2011 7:30 pm
Are you blowing up the gears or the differential? Also, what kind of gear oil are you using? Maybe it's just bad luck, but it could also be driving style. I would assume if you are around stock power level then it's not driving style related. The only time I blew a transmission was when a dowel pin flew out of the flywheel, which was due to rust working it out under normal driving. I also lost a 4-speed that went by natural causes on a 200,000+ mile motor.
PostPosted: Wed Jun 08, 2011 11:33 pm
Im hoping it's only badluck because i have just put in the 3rd gearbox.
The first gearbox it was 2nd gear, second one was the diff
PostPosted: Fri Jun 10, 2011 1:05 am
the km210 should say km210 on the bottom.
