It is currently Wed Oct 22, 2025 12:58 am
PostPosted: Fri Apr 08, 2011 8:01 pm
Negative Nancy
Im going to do a cat delete on my summit and have a few lenghts of pipe to have welded in and need to find the nearest diameter to where the pipe enters the cat. I think the cat removal will allow the engine to breath a little better. With 160k on the cat, im sure its a liitle plugged up.
Thanks,
PostPosted: Fri Apr 08, 2011 8:35 pm
http://info.rockauto.com/Walker/Detail. ... -10754.jpg
Appears the exhaust clamps are 1-3/4", so that should be the outer diameter of the tubing in the system. Sounds familiar when I worked my 1.5L exhaust back together.
PostPosted: Fri Apr 08, 2011 8:55 pm
Negative Nancy
I did search around, didnt find any one specific answer. Thank you
PostPosted: Fri Apr 08, 2011 8:57 pm
Negative Nancy
Mine has stock exhaust, but the pipe before the cat def looks larger, just like in the walker diagram.
