It is currently Wed Oct 22, 2025 3:38 am
 Post subject: High rpm miss
PostPosted: Sun Nov 14, 2010 2:11 pm
History on this car:
1990 Dodge Colt GL Automatic
53,000 miles. Garage kept.
Averaged about a thousand miles per year for the last 10 years.
Bought this car Cheap because of a bad ECU.
Things I have done since I bought the car.
Cap, rotor, plugs,wires, fuel filter, and ecu.
I have the same issue with a known good ECU.
This car has a miss at higher rpm's. It runs great till approaching 50 miles an hour then I get the miss.
Any thoughts will be greatly appreciated!
George
 Post subject: Re: High rpm miss
PostPosted: Mon Nov 15, 2010 12:02 am
Owner/Admin
Check the boot of each spark plug and if you have any that are white or grey, you dont have a good tight connection. Sorry, its hard to trouble shoot a problem if your not there with the car!! So that's my guess. :oops:
PostPosted: Mon Nov 15, 2010 2:08 pm
I'd try a different MAF.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sat Nov 27, 2010 11:32 am
That was it! Thanks Dan
