It is currently Mon Oct 27, 2025 8:39 pm
 Post subject: ported and clipped?
PostPosted: Mon Mar 10, 2003 10:35 pm
can someone please explain a few things for me. What does ported and clipped mean and also what the difference between internal/external wastegate what are the advantages/disadvantages
PostPosted: Sun Mar 16, 2003 3:16 pm
A ported and clipped turbo means that the turbine housing inlet has been ported out larger to flow more, and the clipped part means that the turbine wheel has been reduced, letting more gas's flow through it. Internal wastegates are what come stock on most cars. Where the wastegate i built into the turbine housing, external wastegates are an extra you can buy, weld onto your exhaust manifold and run the gate like that. Externals are less likely to boost creep.
