It is currently Mon Oct 27, 2025 2:31 am
 Post subject: NEED INFO
PostPosted: Wed Mar 05, 2003 2:46 pm
ok i want to rebuild my 4g61t
and i need to know a couple things
for starters anyone know how much a gasket kit costs
cuz i am currently in southamerica
and i can get one for 50 U:S $
that is japan parts
2 is it the same kit for the 1990 eclipse ?
3 what are the part numbers for the front sway bar bushings and
sway bar end links
4 what else should be changed while in the engine
rings? bearings? and thier part numbers please
if someone has the part numbers for the rings that would be great
thanks for your help
89 mirage turbo
 Post subject: Re: NEED INFO
PostPosted: Wed Mar 05, 2003 5:51 pm
How how much a gasket kit costs
APPROX $200
Cuz i am currently in southamerica
No, sorry.
That is japan parts
The 4G61T comes with smaller intake manifold gasket/smaller exhaust
manifold gasket/ water different water pump gasket. So the answer would be no...
What are the part numbers for the front sway bar bushings and
sway bar end links
Dunno, Sorry
What else should be changed while in the engine
rings? bearings? And their part numbers please
 Post subject: does anyone know
PostPosted: Thu Mar 06, 2003 3:15 pm
well does anyone have the part numbers for the
gasket kit
i found the numbers for the sway bar bushings and links
thanks
89 mirage turbo
PostPosted: Thu Mar 06, 2003 5:07 pm
Here We go!
Complete Gasket Kit Head and Block: MD997473 or replacement part number : MD974634
Head gasket kit : MD997469 or replacement part number: MD974633
Hope this helps! :wink:
ColtMax
