It is currently Wed Oct 22, 2025 10:15 am
PostPosted: Thu Oct 01, 2009 1:12 pm
New problem as of yesterday...
After starting, will stall sometimes with clicking beforehand. Will start right back up (sometimes with clicking) then stall again. Battery icon will be on (but I think this is on when key is in ignition position w/o engine on?).
After the first few times this happened, I put in new positive and negative battery connectors (the stock were cracked/crumbling) and secured the battery against any movement.
Still happening... any advice would be fantastic as this is the daily driver.
Thx much,
#89
PostPosted: Thu Oct 01, 2009 3:37 pm
Ecu would be my guess, the clicking would be the mpi relay turning on/off as the ecu dies and it loses signal.
PostPosted: Thu Oct 01, 2009 5:33 pm
Thanks Mech...Yeah - searching the boards info (ECU* worked) seems an ECUish problem... I'll be swapping in a 'spare' (wish me luck [-o< ) from a box of "back-up parts" that came with car. Photos of ECUs w/ #s below. What's with the upright; memory looking 'chip'? Also, the brackets although close, are different and off by a few good millimeters? Anyone know what the heck ECUs these are- I'm still trying to find Flying Eagles ECU list...?
Thx,
#89
PostPosted: Thu Oct 01, 2009 6:44 pm
just typed in the ecu in google..first site came up as.
http://www.chryslerecu.com/partindex/ecuoem135.htm ..... mods might wanan make this link a sticky..
Scrolling down to the 2 part numbers here is ur answer.
http://www.chryslerecu.com/finditfast/s ... tton=13988
and
http://www.chryslerecu.com/finditfast/s ... ton=107436
hope this helps.
PostPosted: Thu Oct 01, 2009 7:28 pm
Aaah... good old Google! :wink: ... thx slowdsm!
According to that site the ECU that was in the car was a Colt application.
Now here's the good part - the 'spare' the guy included with the car is from a -
1990 Dodge D150 Pickup Truck (3.9-liter V6)?! #-o
Well here's the thing...
to keep things moving along between posting...
I swapped the board into the original housing...
reinstalled it...
turned key...
it starts/runs!? :-k
(Clicking/dying problem is gone also).
The the colt 1.5 million dollar question now is - what problems or harm can this wreak? :-?
Big temptation though. Can't- stop - myself - from - test - driving - it... 8-[
Will report back with damages/findings!
Updates soon,
#89
PostPosted: Thu Oct 01, 2009 7:55 pm
The D50, aka the mitsu mighty max, also came with a 4g63t variant, which if you have a 4g61t, will work (but need some mods like injectors and maf).
If you scroll all the way down, you'll find the information archives (the one I reference in the "READ THIS FIRST" post at the top of this forum). When checking through the "Engine/drivetrain" subforum, you'll find the ecu # list post. ;)
http://www.4g61t.org/forum/viewtopic.php?f=2&t=9992
PostPosted: Fri Oct 02, 2009 6:41 am
So took a quick trip (a few miles, through all 4 gears) using a
MightyMax/1990 Dodge D150 Pickup Truck (Edit: 2.4L? {Orig referenced as 6 cyl}) ECU in the Colt 1.5 (!)...
(Non scientific/'seat of pants' test):
~About 1-2 seconds of low idle (then to regular) on start up.
~No Check Engine Light.
~Smooth acceleration.
~Filter box area seems slightly 'louder' on throttle now?
~Have not traveled far enough to guage fuel consumption.
Still concerned on potential harm/havoc running this setup? Any insight?
Possible electrical issues? Would the different sensor settings (e.g. knock sensor) affect engine longevity?
Much Obliged,
#89
PostPosted: Fri Oct 02, 2009 3:10 pm
It's more likely that you're running the 4 cylinder mighty max ecu or that the ecu isn't labeled correctly/the numbers on it weren't read right. I don't think the v6 ecu would run at all on a 4 cylinder car.
PostPosted: Sun Oct 04, 2009 2:52 pm
Mechacode; All, Those are my actual pics above and the data is from that site provided by slowdsm. Even if it is (most likely) the 4 cylinder (which I think was a 2.4L?) I'm impressed at how well it runs (actually better - although my 1.5 ECU may have been last leg since I got car).
MightyMax/1990 Dodge D150 Pickup Truck (3.9-liter V6) ECU in the Colt 1.5 (!)...
Update - Findings after driving 241 more miles:
All of the above plus,
~1-2 seconds of low idle on start gone - now = initial 40-50 sec of slight (500 to 800 RPMs?) up down idle.
~241 heavy foot miles divided by exactly 7 gallon fill up on d@mn near empty = ~34.4 MPG - so slight decrease on MPGs...
(was getting 36 and change w/ stock ECU - with tune-up 'in progress').
If anyone has a base model A/F spec - could probably test mine to compare?
Looks like this sucker is staying in for a bit (at least until repair/replace 1.5 ECU).
Banzai,
#89
PostPosted: Wed Oct 07, 2009 9:09 am
By the way do the spring clip retainers bend easily? For such a simple task, was a real pain in the balls putting it back in :headache: - there was NO way the ECU was lining back up with the bolt holes (with the Mighty Max board swapped into the Colt housing) - at least (most) got the ground bolt in securely...
Thx,
#89
