It is currently Mon Oct 27, 2025 8:55 am
 Post subject: My EVO 5 Coupe
PostPosted: Fri Jul 17, 2009 11:13 pm
so i ran into someone from the board here at a hondas of new england meet :wink: named keith. had a cool little GT. decided i would show you guys what my 3rd Mirage has been up to.
first one:
second one:
third one august 2006:
april 2007:
august 2007:
may 2008:
july 2008:
august 2008:
october 2008:
november 2008:
december 2008:
march 2009:
may 2009:
june 2009:
july 2009:
you can check out the mirage garage, right here:
http://www.mirageforums.net/garage_vehi ... ifications
aloha!
 Post subject: Re: My EVO 5 Coupe
PostPosted: Sat Jul 18, 2009 8:49 am
Whats up man? The car is looking good. I've always likes the 5th gen coupes.
PostPosted: Sat Jul 18, 2009 11:06 am
hey buddy :) some of your parts are on this car remember? im RPW from MPF.
PostPosted: Sat Jul 18, 2009 12:31 pm
I know you posted your location as MA but any chance you were in NJ sometime last year before November? :D
I saw what i believe is your car waving a thumbs up while heading to work on the NJ Turnpike.
PostPosted: Sat Jul 18, 2009 1:10 pm
very possible. flat black 3G ? august i drove through jersey.
PostPosted: Sat Jul 18, 2009 2:32 pm
Wow!!
Yes that was you.
PostPosted: Sat Jul 18, 2009 2:56 pm
friggin awesome :supz:
PostPosted: Sat Jul 18, 2009 3:37 pm
Yeah, I know who you are. I think I have parts on most everybody's car. :P
PostPosted: Mon Jul 20, 2009 10:17 am
Pimpin aint easy!
PostPosted: Mon Jul 20, 2009 8:44 pm
Werd! So, glad to see the car has come together and you are enjoying it. I assume because there are no photos of the car on jackstands, it means you use the car more than most of us here. :lol:
PostPosted: Mon Jul 20, 2009 9:12 pm
it is acceptable... and always for sale for a decent price ;) i have put nearly 100K on the car since i purchased it. the bottom end is TIRED.
in the works is putting in a built 1.5, recipe courtesy of some PR folks, and turbocharging it. hoping to get over 250whp on a daily tune. shouldn't be too hard since most nearly double the HP with no internals. i've had the parts forever however time is a problem.
it has not always been fun and games though. i am constantly plagued with issues on the front of the motor dealing with the crank, timing gear, crank pulley and pulley bolt. on this motor my crank is worn on one side allowing the timing gear to flop around a good 1/8th inch and i've snapped a bolt or two off in there also. probably what started this mess. i've since replaced the timing gear and alot of the play went away but there is enough to put a feeler gauge in.
another mistake i made... needs atleast 24 hours of drive time. i gave it 25 minutes and the loctite acted more a lubricant.
and one time earlier this year i forgot to drain the coolant before changing the water pump :)
PostPosted: Mon Jul 20, 2009 9:24 pm
one of my many autox videos, this one on street tires-
http://vids.myspace.com/index.cfm?fusea ... D=33647652
quick little walkaround during the winter, before i wrecked the front bumper and swapped out the GROSS flowmaster muffler for a 3G eclipse GT one. you can also see my wideband, evo5 wheel and evo6tme cluster-
http://vids.myspace.com/index.cfm?fusea ... D=47789488
driving through flooded roadways, about 20 minutes before i tore the bumper off on some debris sitting in the deep water. 2nd gear pull at the end-
http://vids.myspace.com/index.cfm?fusea ... D=48144346
PostPosted: Thu Jul 30, 2009 11:23 pm
hey whats up this is keith i met you at the meet
PostPosted: Fri Jul 31, 2009 10:19 am
holla!
PostPosted: Tue Aug 11, 2009 10:18 am
WOW! thats alot of thread locker. I wouldnt use that much on 20 bolts. It only needs a strip from top to bottom in order to lock it down... Anyways nice progression on the car man. I thought for sure it was turbo'd or swapped or something.
