It is currently Tue Oct 28, 2025 1:47 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: Sold
PostPosted: Fri Feb 13, 2009 1:29 am
Sold, thanks guys.
PostPosted: Fri Feb 13, 2009 5:58 am
That thing is AWD? Crazy... :o Good luck with the sale! BTW, would it be difficult to swap in a 4G63T into it?
PostPosted: Fri Feb 13, 2009 7:00 am
No.....it wouldnt. There are a couple of LHD versions in Bahrain that have been swapped.
PostPosted: Fri Feb 13, 2009 10:47 am
Oh yeah? What mounts to they use to do it? Also, could you bolt up the AWD eclipse transmission to it as well? Thanks for any help!
PostPosted: Fri Feb 13, 2009 11:10 am
PostPosted: Fri Feb 13, 2009 11:39 am
http://www.4g61t.org/forum/viewtopic.php?f=42&t=27493
PostPosted: Fri Feb 13, 2009 12:07 pm
Alright, But I am assuming the wiring harness would still have to be swapped out to accept the 4G63T? Would it being RHD make it any more difficult for the 4G63T/AWD DSM transmission swap? Thanks for all the help guys! :D
BTW - What mounts are needed to do the swap?
PostPosted: Fri Feb 13, 2009 12:35 pm
The transmission is a W5M31, so a T/E/L,GVR4 W5M33 will fit without problem.
See more info on drivetrain compatibility here: http://www.pixcl.com/summitgtx/awdlancernotes.htm
Of course, there would be no FWD base hacking needed as it's already AWD
Nice... so no hacking at all is needed to put in the AWD DSM transmission... alright thanks. :D
PostPosted: Mon Mar 09, 2009 3:31 pm
Full spec sheet can be found here http://www.goo-net.com/catalog/MITSUBIS ... index.html
PostPosted: Wed Mar 11, 2009 4:33 pm
I wonder if you would be able to Title that thing in the US?? What type of title do you have for it?
