It is currently Sat Apr 20, 2024 9:38 am
Post new topic  Reply to topic  [ 47 posts ]  Go to page 1 2 3 4 Next
 Post subject: Brake upgrade guru's!
PostPosted: Sun Mar 02, 2008 8:33 pm
Hi guys,
can i remove the stub axles from the hub without removing the hub from the car.
i was thinking i could just use a gear puller
im sure its called the stub axle :? the bit with the four 12mm bolts that holds the rotor :D
cheers :)
PostPosted: Sun Mar 02, 2008 8:41 pm
no. have to unbolt the hub from the car and press it off
PostPosted: Sun Mar 02, 2008 8:49 pm
bugger :(
PostPosted: Sun Mar 02, 2008 9:17 pm
or as i recall you can use a slide hammer but the inside seal wont go back in. so you have to take the bearing off and put a new seal in and then press it back together with the axel, but it is much easy to take the nuckle off and use a press
PostPosted: Sun Mar 02, 2008 9:35 pm
yea i was just being lazy :)
hubs are coming off now.
PostPosted: Sun Mar 02, 2008 9:48 pm
There was a writeup moved to the archives a few months ago explaining how to pull the hubs with a slide hammer. It may be worth a try but I don't know about using the axle nut to pull it all back together. Sounds kinda iffy to me, I think I'd be safe and use a press.
PostPosted: Sun Mar 02, 2008 10:05 pm
yea just went out and brought a press.
p.s. tie rod ends suck!
PostPosted: Sun Mar 02, 2008 10:40 pm
i was just repeating what i remembered from the post i saw.
the tie rod ends arent bad if you use a hammer and hit the knuckle at the
tie rod end it will pop right out
PostPosted: Sun Mar 02, 2008 11:05 pm
that was easy compared to this f*(&^&^ lower ball joint.
it just laughed at my two arm gear puller!
PostPosted: Mon Mar 03, 2008 7:13 am
If you're replacing everything anyway just use a pickle fork. It tears the dust boots but it will come off for sure if you put enough arm behind it. :P
PostPosted: Mon Mar 03, 2008 7:25 am
i'll give one of these are try tomorrow
http://www.kincrome.com.au/web/catalogu ... umber=2210
if that doesnt work im just gunna f*&^ shit up with a sledge hammer and pickle fork!
PostPosted: Mon Mar 03, 2008 10:43 am
I use a 4x4 ball joint/u-joint remover kit from the bargain basement type stores like Princess Auto (READ cheap offshore metals). Works a charm and never have to grab a hammer. Even worked to unseize my brake caliper sliders that wouldn't budge when I got the car. :o I'll take a picture for reference as to what I'm talking about.
PostPosted: Mon Mar 03, 2008 10:51 am
Think I paid $40 on sale or something like that:
I had no success using a cheaper $8 ball joint removed tool similar but not identical to the one you have linked t04garret, so I went all out on that little bugger with the kit! :lol: I still have to pickle fork my tie rods but they only have to come apart when things get really tough, or as you are doing with the whole hub coming off. I refrain from hammering on the parts that keep my wheels pointed straight ahead. I realise that hammer on the joint can oval it just enough to get the part loosened, but I now will have to carry my son in the car, and I'd rather not take a chance with 20 year old, nearly 200km travelled cast iron. :)
PostPosted: Mon Mar 03, 2008 2:57 pm
Those work great I use those on my ball joints and tie rod ends all the time.
The first time you use one when the ball joint/tie rod makes a huge noise you'll think something broke and it killed you.... But its supposed to do that surprisingly...
LC '01 Accent GSI - Silver
PostPosted: Mon Mar 03, 2008 9:47 pm
Don't forget you must replace the wheel bearings when you remove the hubs. That's another $100 but you should be able to get a kit from Coventrys that also includes the dust seals.
