It is currently Sat Apr 27, 2024 12:39 am
PostPosted: Tue Dec 18, 2007 4:52 pm
I searched and searched and couldn't find much about the FFD eBay lsd insert. I figured it would be like most eBay parts and would do anything but "bolt in", but know write ups or reviews. So, I decided I would save about $80 and order it. The seller claims that the springs are already upgraded to perform better than the phantom grip. With my transmission already being out I knew it wouldn't hurt to try. I have never torn apart a tranny before so this was all a new experience. I followed the vfaq on the BMT lsd insert exactly. It was the most helpful of all.
Getting the tranny apart was pretty easy. The only thing that you really had to be careful about was prying/pulling the 5th gear assembly apart.
That is when I had everything apart.
I next pounded out the orignal small and large pin in the stock diff. These basically fell out and I didn't have any trouble with them at all. Next, I began to squeeze the insert closed with a vice and lock it closed with the pins and plates. As soon as I released the pressure the little aluminum plates that came with the lsd broke and sent parts flying everywhere.
Once I found all the parts I went ahead and made my own plates in my two minutes using a piece of mild steel I found.
I know they look like crap but I spent a total of 2 minutes on them.
I tried it in a vice with my new "custom" plates
It seemed to be holding. I then tried to pound it into the diff. This was easier said than done. The first time I hit it one of the plates slipped off and sent parts flying everywhere for a second time. On the second time, I just kept tapping and it eventually went in.
This is after I reinstalled both pins in the diff. seems to fit alright.
So far, the lsd insert hasn't been too bad, besides the plates. I haven't had a chance to try it out yet as I am waiting for a few tranny parts. I will add to the post once this is done.
PostPosted: Wed Dec 19, 2007 10:35 am
when are you going to install it and drive it to see the effects it has?
PostPosted: Wed Dec 19, 2007 11:35 am
I bought a new transmission and I am just waiting for it to be shipped to me. Then I will swap diffs and throw it in. LSD and and snow tires will surely be awesome around here where it has been snowing a couple inches every week. I will post as soon as I know of it works/breaks.
PostPosted: Sun Feb 10, 2008 1:53 am
Well I thought I should update this now. With the LSD insert installed and about 200 miles on it. I can say I am 100% satisfied. It's like driving a completely different car. The car will actually stay in its own lane under hard acceleration. It does awesome in snow and ice. I will repost if anything changes.
Thanks
PostPosted: Sun Feb 10, 2008 12:28 pm
Please keep this updated as you put more miles on it! And if anything happens.
thanks!
