It is currently Sun Oct 05, 2025 2:32 am
PostPosted: Wed Oct 11, 2006 10:49 am
The fan that blows hot or cold air won't come on when you turn on the switch. Nothing happens. I believe it's a fuse, but I checked every fuse in the car and under the hood. looks fine. am I missing something? :huh:
1992 Mitsu Mirage 4g15 4 speed auto 134k miles
PostPosted: Wed Oct 11, 2006 11:11 am
have you had the dash out at all?
could be unhook from the thingy you turn. know
mine is for the heater/ac controls. i gotta reach
up under dash to switch it. not in the mood to
pull the whole dash out again. unless a new
ones going in, or pull out harness for another car.
PostPosted: Wed Oct 11, 2006 1:44 pm
There is a relay for the fan, it's called heater relay. The blower motor itself went out on mine a few years ago. Greg
PostPosted: Mon Oct 16, 2006 8:32 pm
could someone pinpoint where the heater relay is? I found the fan relay under the hood..not sure if it's for the heater.
PostPosted: Tue Oct 17, 2006 7:32 pm
The heater relay is under the dash above the fuse box. The fan relay's under the hood are for the radiator fan and AC condensor fan. Greg
