It is currently Mon Oct 27, 2025 2:19 pm
 Post subject: DSM connectors (pics)
PostPosted: Fri Jul 21, 2006 10:29 am
I was just woundering what these conectors on the dsm harness are for
bigger pic
http://i42.photobucket.com/albums/e349/ ... ectors.jpg
do they need to hook up to anything ?? if so where thanks for the help
Turboed FwD laser
90 Dodge colt 4g63t swap ,680cc injectors, Greddy Profec-b Spec ll Boost controller, Greddy full auto turbo timer, Apex'i S-afc ll, Front mount intercooler, 2.5 inch piping, 3" GM MAF/With MAFT
PostPosted: Fri Jul 21, 2006 11:38 am
I didn't use the top one on my swap, I just taped it off. I believe it went to the DSM fuse box. The bottom one is from the C/S/M fuse box, correct? If so it's the one with the black/yellow wire that goes to the little tab on the starter. It sends power to the starter once the key is in the start position. The black/yellow is the only wire I used from that connector.
