It is currently Sun Oct 26, 2025 9:29 am
 Post subject: ECU pinouts
PostPosted: Sun Oct 09, 2005 10:25 pm
Guys, i put three ECU pinouts in the archives. 4g15,4g61,and 4g63 are represented with the accompanying voltages for each pin!!!
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Oct 10, 2005 9:06 am
Nice job Soc! I helped a bit in that, there were large spaces and no highlights for the socket connector names, so I hope you didn't mind. Cheers for more info gathering.
BTW, where are the 4g15 pinouts located, I only see the 4g63 NA, and 4g61 NA setups listed?
PostPosted: Mon Oct 10, 2005 9:36 am
Dont mind the help at all. Thanks!
The 4g15 ECU pinout is in the 4g15 archive :wink:
I'm working on more cross-reference material to archive in a similar way.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Oct 10, 2005 9:46 am
I also just updated the pinouts so the picture shows.
Thanks Photobucket!
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Oct 10, 2005 9:47 am
Should have known, haha. IF you talk to Paul, we can add the pics to the archive/photo albums so that they will always show up. :D
PostPosted: Tue Oct 11, 2005 9:24 am
Paul.........Can you save those pinout pics? :D
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Oct 11, 2005 9:26 am
Nobody Important
You do it.
Register for an accout in gallery.4g61t.org
reply to my post in the mods forum for access
insert away
-paul
