It is currently Sun Oct 26, 2025 8:14 pm
 Post subject: problem with valve
PostPosted: Sat Aug 06, 2005 8:46 pm
hai, i m new here..i seem to have a problem when everytime i started my 61 engine, the valve tappet seems to make a weird sound like (tet..tet..tet) and after about 1 minute its gone...sorry if my english sound terrible...And what is the differrence between the 61 and 61 RS engine??
4G63T - 95 Mirage Cyborg R
MODS : 255lph, SARD AFPR, NGK (spark plugs and cable), SSteel IC, FMIC, big 16g, TypeS BOV, MBC, 2.5" Exh (No cat)
PostPosted: Sun Aug 07, 2005 4:47 am
Looks like your hydraulic lash adjusters are a bit gunked up. Try a different weight or brand of oil and look if it goes away. If it only makes that clicking when cold, and it doesn't become worse, you shouldn't worry about it.
Where the Helligkeit does a 4G61 RS engine came out of? :o
Got rabies?
PostPosted: Mon Aug 08, 2005 8:08 am
eemm hydraulic lash adjusters ??where are these thing located?? by the way,, the 4g61t RS usually use a different kind of intake manifold not the CYCLONE IM but the ECI MULTI IM.. bcause here in malaysia the 61t halfcut came with two different type of engines...that i believe to be the RS and non RS version...
PostPosted: Tue Aug 09, 2005 5:19 am
The lash adjusters are inside the cylinder head.
Got rabies?
PostPosted: Tue Aug 09, 2005 9:32 am
Nobody Important
http://www.ce.rit.edu/~mezz/gallery/lifters
In there
Look at the last picture. The left side still has the rockers on and the right side has them removed exposing my nice new liifters
PostPosted: Tue Aug 09, 2005 11:04 pm
Must.........get.........new...........lifters.......this.........ticking.........is........driving..........me............crazy............every............morning.
My Lantra's 4G67 does the same damn thing, although it has gotten quite bad where it ticks for a good 5-10 minutes driving on a cold morning. Letting the engine warm up before driving just makes it worse :( Engine oil flush has made it better but I just need to bite the bullet and get some new 3G lifters with the larger oil hole. Problem is they are expensive here in AU and there are 16 of them.
PostPosted: Wed Aug 10, 2005 5:08 am
If I hadn't needed mine I would sell them to you, but send Hybrid Connection a shout, or better yet call them. They did a group buy on this stuff and shipping for such a small box shouldb't be too bad. I would suggest having Hybrid send the goods directly from their end though and not the manufacturer (we had a little trouble their with the paperwork at customs). Food for thought.
*EDIT* Just received my government money back! UPS will get to hear why they must pay me back now.
PostPosted: Wed Aug 10, 2005 9:59 am
Nobody Important
if you tick, try 15w-50 oil. Thats what I run and it calms it down some
PostPosted: Wed Aug 10, 2005 11:25 am
emmm i C..i am using semi-synth 15W-40 oil ,,every morning i start the engine, it ticks in about a minute...when the engine warmed up a little, the tick disappears ( but if u put your ears closer to the engine, you could hear the tick is still there).
PostPosted: Wed Aug 10, 2005 11:46 am
The try a thinner oil, like 5W-40 and look what happens.
Got rabies?
PostPosted: Wed Aug 10, 2005 11:54 am
ok ,,, i'll try ...thanks :)
PostPosted: Fri Sep 02, 2005 6:35 am
What if i clean all the hydraulic lifters....will it make any different??? or i have to change all lifters??what about using oil flush,, will it works?
PostPosted: Fri Sep 02, 2005 2:08 pm
You can try cleaning them w/ ATF or Diesel fuel one by one by soaking them in that stuff.
Got rabies?
PostPosted: Fri Sep 02, 2005 9:09 pm
Thanks for replying....
I lived in a hot climate country ,,, therefore i cant use thinner oil...that is why i have to find other way to solve the problem... i m going to clean all hydraulic lifters and use IDEMITSU 20w 50 oil because my mechanic said that turbo engines are not suitable with thinner oil especially in hot climate country.....
thanks again ethereal
PostPosted: Mon Oct 03, 2005 11:00 pm
dear all,
mine to having same problem, but mine the duration is longer,, sometimes even car go up to 30mins, while im driving also car hear the sound, im not sure what type oil i used previously, but im going for service next week, maybe can recomend what kind of type of oil so that i may try.
Note: Me too living in hot climate. :(
" whenever there's no other way, there's always sideways... "
