It is currently Sat Apr 27, 2024 2:52 pm
PostPosted: Mon Jun 13, 2005 3:18 pm
This thing is a nice upgrade from the stocker for most guys running anything from a 14b to any flavor 16g. Depending on your mods and boost you will need 450cc or bigger injectors.
I installed it this weekend with a little tweaking. My tank was a ^%$& to access since my 3" exhaust is really close to the drivers side tank nut. I had to do this with the tank only partially down but I did get the sending unit out.
The install is pretty similar I think to the walbro so there are no pics so don't ask for any. :P
The pump is not as fat as the factory unit so you will need to make up the difference for this (IE zip ties or an isolator). Also this pump has a clip style harness, I used 2 slide on crimp connectors that are shielded and it worked great.
I did not rewire the pump yet since I still need to install my DSM SMIC.
This is a cheap upgrade since you can find them on EVOm for $25.00 and up. They flow close to the wally 190lph.
http://www.roadraceengineering.com/fuel ... wrates.htm
My current mods are
3' exhaust
small 16g
Evo8 pump
1990 DSM 5 speed ECU
450cc
Soon to be installed
DSM SMIC
5 knob AFC
Glen
89 Colt Turbooooooooo
Users browsing this forum: No registered users and 37 guests
