It is currently Mon Oct 27, 2025 12:17 pm
PostPosted: Mon Apr 04, 2005 11:48 am
Hi everybody,
I'm from Australia and have had so many dramas finding wiring schematics so I can connect the standard tacho to an autronic SMC. I am currently running an aftermarket item on the dash but would prefer to run the OEM one to keep my sleeper look. Any suggestions or links that could help me?
PostPosted: Mon Apr 04, 2005 5:08 pm
There's only two wires that need to be connected on the dash end, TM and TM ground, they have small screws going into them that you can undo and put a ring style crimp piece onto.
TM ground just needs a good earth, TM goes to the tach signal wire that goes to/from the ecu.
