It is currently Mon Oct 27, 2025 4:56 pm
PostPosted: Fri Apr 01, 2005 12:19 am
4g61t Delinquent
Ok since my 89 Colt GT 4g15 automatic went "south" on me im gonna venture a new path and resurect a Pheonix from the ashes of my 4g15.
Since I Have a 4G64 SOHC 8v block in perfect running condition in my garage i plan on just putting that together and dropping that in for replacement for my 4G15.
First order is removing the balance shaft since it went out of wack and enlongated the bearing hole in the block. But I do know for certain I will need the following parts for this:
* FWD Intake manifold
* SOHC 4G64 injectors
* SOHC 4G64 distributor
* SOHC 4G64 ECU
* SOHC 4G64 MAF
Now the mounting is somewhat shady. Do i use the 4G15 or 4G6X CSM front timing mount?
And I take it I will need the 4G6X block mounts and 4G61 "roller" mounts to the front crossmember to get it properly aligned(sp?)
- Paul
I own a CSM.
PostPosted: Fri Apr 01, 2005 1:52 pm
Slap on a DOHC head :)
PostPosted: Sat Apr 02, 2005 8:36 am
Paul,
Just get the engine in place with DOHC lower/tranny mounts in place and see where that leaves you see what compatible with going there..
LC '01 Accent GSI - Silver
PostPosted: Sat Apr 02, 2005 1:35 pm
AFAIK you'll have to use a 4G6x timing belt mount. The diesel engines (4D6x) that came in the CSMs have a head design similar to the SOHC heads and still have that mount.
Got rabies?
PostPosted: Mon Apr 04, 2005 3:13 am
4g61t Delinquent
ok so i also need to use the automatic tranny mount for a DOHC equipped CSM or just use my stock km-171/4g15 tranny mount? :-?
I own a CSM.
PostPosted: Mon Apr 04, 2005 3:40 am
Uh... ask Berserko! :D I remeber faintly that the 4G64 SOHC bolts to stock 4G15 tranny mounts. I think it was Steward Dibbs who did that.
Edit: just scroll down so Paul's above post is in the center of the screen. You can see SIX bunnies hopping around. Darn, this is annoying. Anybody got a sawed-off? :twisted:
Got rabies?
PostPosted: Mon Apr 04, 2005 6:08 am
I think you'll want the 4g6X tranny mount get it from your local elantra at the wrecker. Can have it out in like 10 mins..
