It is currently Tue Oct 28, 2025 2:58 pm
Post new topic  Reply to topic  [ 140 posts ]  Go to page Previous 15 6 7 8 9 10 Next
PostPosted: Fri Jan 27, 2012 10:25 pm
Went to Whistler bearing and it was a standard thread. ... It has a new copper crush washer but the fitting didnt thread in completely straight.
What do you mean not straight? I'd look into that before anything else. Band-aides work on cuts.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Fri Jan 27, 2012 11:34 pm
The guy at whistler bearing screwed it in while I was there. It only leaks a little Im gonna try some kind of sealant on the treads maybe even jb weld?
PostPosted: Fri Jan 27, 2012 11:45 pm
I use pipe tape on most of my threads, you may want to consider stacking 2 new copper crush washers only if it won't bottom out with one, or maybe they make thick ones?
Don't jb weld, that shouldn't be in your csm dictionary yet lol
PostPosted: Fri Jan 27, 2012 11:52 pm
Sounds like a bad idea.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sat Jan 28, 2012 12:04 am
What part?
PostPosted: Sat Jan 28, 2012 11:41 am
Not figuring out what the problem is and trying to use sealant on the threads of a banjo fitting.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Sat Jan 28, 2012 11:49 am
Yup, disaster waiting to happen. But I have run the fittings on mitsu turbos with tape and not had any issues. But the fittings worked and went in all the way as well. This seems to be going downhill fast with what looks like an bad outcome. You need to really stick with what people tell you. Some of the things you are doing or saying are far from being right and is what give DSM's a bad name. There is no need to hack ANYTHING on these cars with all the aftermarker support we have. There are so many bolt on applications the recipes have been written thousands of times now with success.
Figure out what is wrong before you go further. And please don't ever JB weld anything. Repair things the right way and save any trouble and heartache down the road.
1985 Mitsubishi Cordia
Build in progress
PostPosted: Sat Jan 28, 2012 3:18 pm
My fitting screws down all most all the way but is a little crooked and not sealing the crush washer flush. Ill try some plumbers tape and 2 crush washers and see if the leak stops. Its actually seams to be leaking less on its own now hmm?
PostPosted: Sat Jan 28, 2012 8:12 pm
Your fitting should not be crooked at all. It sounds to me like you have a standard fitting in a metric thread or vice versa. You shouldn't need to use any teflon tape or more then one crush washer. You need to find a dsm buddy close to you to help you out.
PostPosted: Mon Jan 30, 2012 8:08 pm
Well the leak magically stopped :D I put the car back together and took if for a quick spin around the block. Its slower than it was with the 11b lol Ill get the boost gauge in there tomorrow and see how many pounds it boosting Probly not alot its just running waste gate boost. Next Ill install dsmlink v2, 1050cc fic injectors and 255 wally, 3" down pipe and start to make some power :D
PostPosted: Tue Jan 31, 2012 1:31 am
You really need an intercooler lol
PostPosted: Tue Jan 31, 2012 2:05 am
I have a fmic. I installed the 90 eprom ecu with dsmlink v2 as well today and it fired right up but it seems to be missing. Maybe due to the 90 ecu thinking it has 450cc injectors? Time to find someone to help tune it when I get the other parts installed. Also my front o2 sensor isnt cycling so I need to figure that out first.
PostPosted: Tue Jan 31, 2012 3:07 am
Oh, didnt catch that. Just go into link and change your injector size with the proper deadtime and base pressure, that should fix the miss.
PostPosted: Tue Jan 31, 2012 12:05 pm
My guess is a boost leak if it is slower. Or it is knocking so bad(likely) that is is pulling a ton of timing. Your dsmlink may be set of for something different(injector wise) unless you went in and changed the settings yourself.
Build in progress
PostPosted: Tue Jan 31, 2012 12:32 pm
You should start a build thread or start new threads in the applicable sections as this is getting seriously off the original topic lol :toimonster: ..I want pics so make a build thread :D
