It is currently Thu May 23, 2024 12:35 am
Post new topic  Reply to topic  [ 50 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sun Jan 23, 2005 12:55 pm
Supposedly they bump power up like 15-20 HP. I'm not sure on that. You know, those guys tell you they turbocharged their Daihatsu Mira so it makes 15000000 Hp now or something.
I guess 10 HP could be realistic on a stock engine.
Got rabies?
PostPosted: Mon Jan 24, 2005 2:30 am
:lol: Yeah I know. :) So you haven't personally tried 'em or know of anyone who did?
Well your guess of about a 10hp gain is something but I'm guessing that's just a hairline over if I just used a stock 63T exhaust cam, would you think so?
My Ride
PostPosted: Mon Jan 24, 2005 1:44 pm
Honestly, I just don't know. Those 10 HP were guesstimated. :-?
Got rabies?
PostPosted: Tue Feb 01, 2005 1:28 am
Sir, one more question. Would you know of any "valve-piston" clearance issues if I do put the turbo cams (either stock 4G63T cams or HKS 264's) in my 4G67?
My Ride
PostPosted: Tue Feb 01, 2005 6:48 am
Yes, never ever let the timing belt rip or slip. :wink: Remember, those engines are already interference engines. Other than that, the Turbo cams do not affect piston-valve clearance in any significant matter.
Got rabies?
PostPosted: Tue Feb 01, 2005 8:14 am
No worries there but thanks for the reminder. :lol:
Just the assurance I was looking for. Thank you sir.
My Ride
PostPosted: Tue Mar 29, 2005 11:50 pm
I have a 1.8L DOHC mits in my Hyundai Elantra, where do I buy the balancer shaft removal kit for mine??
PostPosted: Wed Mar 30, 2005 1:25 am
Call your local mitsu dealship and order the 4 parts listed on this page.
http://www.vfaq.com/mods/balance-shafts.html
LC '01 Accent GSI - Silver
 Post subject: 1.8 motor
PostPosted: Sun Oct 02, 2005 7:30 am
I've been told the 1.8 JDM turbo motor has no B.S. (can't confirm that), don't know about Hyundai 1.8.
1991 Mirage 4dr GS (turbocharged)- deceased
1991 modded GVR4
2003 Galant V6
2006 RR Sport
 Post subject: Re: 1.8 motor
PostPosted: Sun Oct 02, 2005 8:22 am
All Hyundais even the 1.6L have BS for some reason. At leaset all that I have seen.
PostPosted: Sat Feb 25, 2006 4:40 pm
I've always "heard" that the bal. shft. removal was worth 10 hp. Since it's a "heard" thing, I would look realistically for 5-8hp. IMHO. I have a set of turbo cams if anyone is interested.
Oh, and the general thought is to retard the exhaust 0ne link which is aprox. 5*. You can check the clearance easily by using a socket wrench on pulley and slowly rotate the crank two revolutions with the plugs out (eases compression). Listen for a "touch" but I'm sure that you will be OK.
PostPosted: Tue Mar 21, 2006 1:34 pm
I did a comparison of stock dsm cams a while back. many of you are members of galantvr4.org - so log in and hopefully it will let you follow this link:
http://www.galantvr4.org/ubbthreads/sho ... Post187568
if not search for "Stock DSM Cam Comparison - pics" under sleepyvr4.
the lobes were essentially measured with a digital caliper, and all measurements and cam types were recorded.
I sit 98 degrees underneath palm trees
PostPosted: Tue Mar 21, 2006 4:54 pm
^^^ I like this guy! :lol: Good info to have at our fingertips.
PostPosted: Fri May 19, 2006 4:42 pm
i was told by a mitsu mechanic that if you retard the exhaust cam by 1 tooth on the belt it made them go better.think it freed them up at higher rpm.i never got round to trying it on my car when i had it thou. :cry:
PostPosted: Mon May 22, 2006 9:35 am
Yes, that is the general mantra. five to seven degrees exhaust retard is called for to get more TOP end. One tooth is about that.
