It is currently Mon Oct 27, 2025 8:54 pm
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 15 6 7 8 9
PostPosted: Sat Feb 05, 2005 12:08 pm
is there a PC or laptop software for the MMcd ???
I have the palm software but I'm waiting for my usb/db9 cable to be able to connect my data cable.
tx
jp
PostPosted: Sat Feb 05, 2005 6:32 pm
The laptop software is not MMcd. But you can get a program that extropolates all the mmcd data into an excel table.
On the vr4 australia forums, there is a guy who made a palm emulator for the pc but you have to be a financial member of the club to get a copy of it.
www.clubvr4.org
Mike
Member #31
PostPosted: Thu Mar 24, 2005 7:19 am
There's something people can do so that one cable can be used on both palm & laptop, just make a crossover gender bender, I just went tx - rx and vice-versa, along with ground to ground, and encased it in resin.
PostPosted: Tue May 17, 2005 6:35 pm
Monsterbishi, I pm'd you about the program for pc's and I just wanted to post in case it was deleted when the server was down. It sounds like it won't work on a mac. Does anyone know if there is a free version for macs? I have a macintosh power book.
THE COLT
PostPosted: Tue May 17, 2005 7:42 pm
afaik, no such software exists for a mac... unless it has some real good pc emulation software that allows for serial port use as well.
PostPosted: Tue May 17, 2005 11:36 pm
I just received my palm whit pocketlogger and i did a little run here's some number..
at 10 psi on 94 octane
rpm:5937
knock:0
timing:24 deg
air flow:1575 hz
o2:0.92 volts
inj p/w:15.13 ms
isc:71 steps
o2 trim:100%
fuel trim hi:81%
fuel trim mid:81%
fuel trim low:85%
wb o2:18.90
i read that when the fuel trim a lower than 100% its because im in a rich condition ? ..
PostPosted: Wed Jul 27, 2005 5:32 pm
for reference, the schematic images have been moved, so here's the palm one hosted on my local mitsu club server:
for a laptop cable you just need to use a db9 female plug instead with pins 2 & 3 swapped.
PostPosted: Mon Sep 12, 2005 10:52 pm
Negative Nancy
Is there any PDA's that you guys would not buy? will one of the new 25 dollars ones work off ebay, or how about the ones that look like mini computers? seems to me that they just have bigger displays... i dunno. on the site where you down load the free software for the pda's, i have seen the compadibility charts but, does that mean they are the only ones in the world that will work, or i guess maybe you get what you pay for? :o
PostPosted: Mon Sep 12, 2005 11:15 pm
I bought a palm m100 off ebay with the serial cable and palm windows CD for $35 shipped I believe, works decent, well enough to tune the car with.
1999 Ford Contour SVT
PostPosted: Tue Oct 18, 2005 9:10 pm
well .. dont buy a visor delux , and dont buy anything with an os that is not upgradable. And also make sure there is a serial cadle available for it !1
1993 TSI AWD big16g 20psi
13.2 @ 101.7 mph -- sold --
Colt 200gt + 20g + 660cc + 22psi
