It is currently Sun May 05, 2024 8:22 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Dec 14, 2004 12:50 am
4g61t Delinquent
SuperPro polyurethane bushings also. have them installed and i likey!
I own a CSM.
PostPosted: Tue Dec 21, 2004 1:46 am
do tell more about the SuperPro bushings, what kit did you buy and what other stuff do they make for our cars, how different is the car?
White 89 colt GT Turbo
tuxedo 91 1GA TSI auto
Silver 91 previa
Silver 2006 G35 6spd Sport sedan F.S.
PostPosted: Tue Dec 21, 2004 11:07 pm
4g61t Delinquent
double posting bastard! :P
i bought the full normal kit. not the caster adjust one but just the full kit.
I own a CSM.
PostPosted: Wed Dec 22, 2004 12:08 am
Ground Control coilovers with KYB AGX's on mine.
89' Mitsubishi Mirage Turbo.
PostPosted: Thu Jan 06, 2005 2:21 am
KYB GR-2's fit all around.
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Sat Jan 08, 2005 12:45 pm
don't forget about Koni inserts:
http://www.koni-na.com/display.cfm?mt_i ... t=Continue
it seems a lot of shadetree folks tend to shy away from these because of the necessary surgery for installation - it is in all actuality very easy! I put these on my Excel(front) with no prior experience. I am noob, hear me roar...
instructions call for cutting the tops of the stock struts off with a hacksaw. :-? ignore those instructions. the key is using a large pipe cutter that plumbers use:
makes a perfectly precise & straight cut without any real effort. you can rent one for an afternoon for practically pocket change if you don't have one laying around(I descend from a long line of plumbers so I in fact had one lying around).
Koni's paired with a good drop spring(I used B+G) can deliver awesome results at a significant savings compared to the price of true coilovers.
91 Hyundai Excel GS - stepbrother to the CSM
88 Piazza Turbo - Italian-Japanese fusion
88 Isuzu Trooper - 4x4 fun!
PostPosted: Sat Jan 08, 2005 4:15 pm
Thats exactly what I did makes life REALLY easy.... no mess did it my living room no issues.
PostPosted: Sat Jan 08, 2005 7:18 pm
My springs where hacked down but my struts where special ordered. Can't remember who, I'll get gack to you. it drove like a dream.
I have never bought a car for more then 500 bucks.
First Car. '75 Toyota Celica GTS- $300
2nd- '89 Dodge Colt GL- $300
3rd- '90 Mitsubishi Mirage- $400
4th- '90 Toyota Pick Up- $500
5th- '93 Mitsubishi Eclipse- $100
PostPosted: Wed Jan 19, 2005 5:27 pm
I can't believe no-one has mentioned my DSS coilovers! I used the koni's with them and did the pipe cutter as well (cost like 15 bucks for one and it cut PERFECTLY) I need to adjust the rear koni's but other than that the car rides on rails!
PostPosted: Thu Jan 20, 2005 12:39 am
Will DSS coilovers and GR-2's work out ok?
PostPosted: Thu Jan 20, 2005 2:22 am
i've heard that the gr2s are really bouncy and since they're not adjustable you'd basically have to get the springs made around the stiffness of the gr2s. konis are adjustable so you have a LOT more flexability with how bouncy you want it.
PostPosted: Thu Jan 20, 2005 5:15 am
Anyone know how much those Koni inserts are (front and rear)? any website/online store that sells them for a good price?
PostPosted: Thu Jan 20, 2005 8:05 am
www.tirerack.com
PostPosted: Thu Jan 20, 2005 12:34 pm
Thanks for the link:
$159 (each) for fronts and $119 (each) for rears = $560
I thought they would be a little cheaper because they're only inserts. Are these the same componenets they use for their "yellow" shocks, im guessing they are because of the price?
PostPosted: Thu Jan 20, 2005 12:47 pm
yes, they are koni yellows, but i'm pretty sure i got them from dss (who shipped it directly from holland to my house) for around 500. ended up being 900 total. too bad their site is experiencing the same difficulties this one was not too long ago...
