a good way to test the tps as follows:
get the thinnest sewing pin you can find and push the point through the middle wire on the tps wiring connector. switch the ignition to ON but dont start the engine, the measurements will be slightly different with the engine running.
Wait for fifteen seconds after turning the ignition key on.
then measure the voltage between the pin and the -ve battery terminal (or any good ground point) with a digital multimeter. with the throttle closed the voltage should be 0.48 - 0.52V. if not then adjust the tps to get the voltage in this range by loosening the screws and rotating the tps.
then smoothly hand-open the throttle; the voltage should increase smothly up to 4 or 5 volts (an analog meter is good for this).
make sure that there are no jumps or discontinuities in the voltage curve. the tps is just a variable resistor, like a volume control on an amplifier, and when they wear out their value can jump around if the wiper leaves the track, or if there is dirt on it.
remove the pin when you're finished and there should be no real damage to the wire.
NB: this is the process for my '91 excel, and i think it will be the same as for your car. the fifteen sec wait is to allow the throttle positioner in the 91 excel to reset, but if your engine has a idle bypass valve you may not need to do this. also if you made an adjustment to the tps, make sure you reset the ecu.
sorry for the long post.
