It is currently Sun Oct 05, 2025 4:03 am
PostPosted: Sun Dec 12, 2004 12:02 am
i have tried to install this part with no luck . if i block off one of the holes on it it runs fine but when it is all open my car does not want to idle ?? i have the 8 valve 4g15 efi . no modifications to fuel rail injectors or ecm.
should i get a different ecm , fuel rail , injectors , or all of it????
opinions needed please
THERE IS NO SUCH THING AS THE IMPOSSIBLE
PostPosted: Sun Dec 12, 2004 4:05 am
4g63t MAF on an 8v 4g15 with no ANYTHING?
Now that's the oddest thing I've heard all week, don't expect the car to run well, if at all.
You should probably upgrade(downgrade, whatever haha) to the 4g37 injectors, MAF, and ECU, and the throttlebody if you can get your hands on one. I'm running the MAF, ECU and injectors, but getting ahold of a 4g37 throttle body seems to be harder than swapping an engine. :-?
But enough rambling, reply back your thoughts and strategies, and we'll work it all out!
-jd
90 Eagle Summit 1.5 - Wrecked
92 Eagle Summit 1.5 - Sold
94 Talon TSi AWD Auto - Sold
PostPosted: Sun Dec 12, 2004 9:31 am
First off that MAF plug is different it won't plug and play you need to make a turbo to non turbo MAF adaptor and second off it will make your car run terrible. Don't do it.
PostPosted: Sun Dec 12, 2004 1:39 pm
I'm not even sure the 8 valve would benefit as much with the 4g37 items. Do some major head porting and swap the 12 valve manifolds and then you may get some good gains. the 8 valve has some seriously small ports! I guess its good for making decent torque lower in the rpm range, but torque at higher rpm is better as you can take advantage of gearing.
But then who knows? If you have access to the parts try it out and let us know. Most all the 4g15 mods have been through experimentation by forum members. (Ive done my fair share :wink: )
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sun Dec 12, 2004 11:54 pm
the plugs are not at all different . the turbocharged mafs i have seen all look the same (externally) as the one my car came with . you know the air can thing .
anyways ....
the screen looking thing is the same however , the bypass tube on the standard 4g15 has one blocked off and it is about half the size . the car runs like shit when i leave the bypass tube open but if i close one of the 2 tubes halfway (on the eclipse maf) the car runs better and it doesnt send too much fuel through ...
for those of you that do not belive that ia m telling you the truth feel free to look in my garage .
PostPosted: Mon Dec 13, 2004 7:29 am
anyways ....
the screen looking thing is the same however , the bypass tube on the standard 4g15 has one blocked off and it is about half the size . the car runs like $%# when i leave the bypass tube open but if i close one of the 2 tubes halfway (on the eclipse maf) the car runs better and it doesnt send too much fuel through ...
Then if the plug is the same you have a NT MAF turbo MAFs are 8 pin connector NT are 6 pin sam as a 4g15 and of course if you do not add the supporting mods for the MAF (ECU, TB, Injectors) it willl run like garbage it has been covered before.
PostPosted: Mon Dec 13, 2004 9:32 am
1.5, 1,8sohc, 2.0sohc, all use the same MAF with the 1.5 having a bypass tube plugged. The 2.0DOHC NA and Turbo use the same style which is slightly different than the SOHC versions. Most notably, the addition of the larger honey comb and bigger bypass tubes. It is possible that the turbo MAF will output a similar signal range but chances are that you'll need the huge injectors and ECU to make it work.(Like the 4g37 setup)Not worth it because the 4g15 just wont suck enough air to warrant that big an airflow meter. It would be just as easy to swap a map based system. :wink:
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Dec 13, 2004 6:17 pm
:-? i did get it off of a factory equipped car . all others i have seen look exactly like it too
i know that there is a different sensor out there but i have not seen it yet
i also tried hacking up a cople of 4g15 sensors as well with similar results
