It is currently Fri Apr 26, 2024 11:21 pm
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 14 5 6 7 8 9 Next
PostPosted: Fri Jul 02, 2004 8:56 pm
I use a pal m105, I was the one with too small guaged wire. The schematic works, I thought that diode HAD to be the wrong way also. Mine periodically stops working, I think sometimes it has trouble "connecting" to the ECU. Even DSMLink sometimes can't "connect". but I just wanted to let everyone know that I too successfully used that schematic.
1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
1989 Colt GT 4g61T (63T build in progress)
1g ECU, Injectors, Exhaust manifold, 16g evo III Turbo, SMIC, and C Exhaust cam -9*
K&N Air filter, airbox cut up, MSD plug wires, NGKs, Apexi S-AFC II, MAF translator, tubular o2 housing w/ dump tube, Full 3" mandral.
Now I ran out of fuel!!
PostPosted: Sun Jul 04, 2004 2:51 am
Ok here is my pin arrangement, this cable is for Palm and the best part is ... it doesn't work!
I have tried it with Visor, m125, Palm III xe - nada.
I traced the wires to the ECU,
I spliced into ECU's harness ( hooked up my A/F gauge as well ) - nothing,
I borrowed another ECU - nothing,
voltmeter shows some kind of data coming out on pin1 ( voltage readings jump), and I don't have Spectrum Analyser :-?
The resistance across pin 5 and pin 2 is about 12.3k.
See what you think:
Got 1970 SS ?
PostPosted: Sun Jul 04, 2004 4:07 pm
*stupid electronics*
the resistor isn't directional [like the diode] is it?
PostPosted: Sun Jul 04, 2004 9:16 pm
no, resistors are not directional. let me check if the diode direction is correct
PostPosted: Sun Jul 04, 2004 11:27 pm
Hmm - it looks right... Make sure teh solder between the pins arent shorting.
Mike
1991 CB Lancer GSR (5dr Hatchback) with 4g61t conversion - 132kw/180hp @ the front wheels. SOLD!
Check out my website: www.members.optusnet.com.au/~onnzo
Member #31
PostPosted: Mon Jul 05, 2004 4:49 am
Sorry DialUps! 156k
This is how I did the one for my laptop, afaik for the Palm version, you should just swap pins 2 & 3 and it should be good to go.
PostPosted: Mon Jul 05, 2004 1:52 pm
The only difference that I noticed is the color of the resistor ( I'm using 1/2 watt version ), even though it shouldn't make a difference at these voltages/currents, I will try finding a 1 watt one (maybe resistor fails to provide 10k+-5% after certain current threshold). Diod is fine, I "pinged" it with ohmmeter by itself and in the circut.
The key problem is that the design/construction is so simple and yet I can't manage to get it to work, pissing me off.
P.S> My cable is for Palm, so I'm using male DB9 connector, the pin assignment should be the same, right?
Got 1970 SS ?
PostPosted: Mon Jul 05, 2004 5:23 pm
You have the pin assignment correct, only thing I'd change on yours is how you had everything just soldered together in one section, on the diag a couple of pages back - the diode and rx/tx link join before the resistor is added into the circuit.
Fault tracing can be so much fun :-)
PostPosted: Mon Jul 05, 2004 7:28 pm
Ok, will try that today.
Got 1970 SS ?
PostPosted: Thu Jul 08, 2004 7:32 pm
No, not working.
Anybody lives in /close to Bay Area, so I could borrow ECU ?
Got 1970 SS ?
PostPosted: Mon Jul 26, 2004 3:20 am
any progress shark?
PostPosted: Sun Aug 01, 2004 11:34 pm
ok, first off i'm a total noob when it comes to this kind of electronics stuff :oops: ... having said that, where are you guys getting these little pc boards with everything on it? is it just the pc side of the hotsync cable? just peel off the black outer cover and the board and chip and stuff is already there or what? thanx!
EDIT - oh yeah, forgot about this... i found this on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... gory=50915
is this what i want?
PostPosted: Tue Aug 24, 2004 1:21 am
im going to Radio Shack tomarrow to get the stuff to make a PDA wire. I hope it works. I bought a Palm IIIxe on ebay tonight for $26 + shiping.
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Tue Aug 24, 2004 5:10 pm
ok, i was apparently on crack when i posted my first post here, i now understand how it all works and whatnot, but i just can't get it to work. i hooked up my multimeter to it and am BARELY getting anything from pin 1 (what should be the approximate voltages i'm supposed to get?). i think i was getting somewhere in the 0.01x range...
PostPosted: Fri Sep 03, 2004 1:54 pm
The sites people have posted here have since gone dead (at least for now?). Anyone have the software somewhere else or something?
3" Mandrel Exhaust w/highflow cat w/Magnaflow. Apex'i AVC-R. TurboXs RFL BOV. Starion FMIC. Big 16g. 2g Manifold, O2 Housing, & TB eblow. Walbro 255. Homemade Poly motor mounts. MSD DIS4 Ignition. ACT 2600lb pressure plate w/street disc. K&N on custom cold air setup.
