It is currently Sun Apr 28, 2024 2:22 am
PostPosted: Mon Jun 21, 2004 8:48 pm
I was wondering if anyone knows what 5 speed will bolt up to a 4g63 RWD. The 63 will be put into a super seven kit car. Thanks
AWD What?
PostPosted: Mon Jun 21, 2004 9:14 pm
Lookin into the starion powered by a 4g63t . I have seen a couple of guys do it. i want to know myself. thanks tee
4G63T Powered C10 In the workin
Injectors wont work
PostPosted: Mon Jun 21, 2004 9:44 pm
the obvious choice would be the mighty max but i hear they are weak. you could talk to shep about having one built.
PostPosted: Tue Jun 22, 2004 9:41 am
Or the Lancer turbo. (a176 model)
PostPosted: Tue Jun 22, 2004 11:41 am
Thanks guys. I figured the mighty max tranny but what hp will it hold?
AWD What?
PostPosted: Tue Jun 22, 2004 2:02 pm
i've heard like 250hp tops but thats just what i've heard so you never know.
PostPosted: Thu Jun 24, 2004 5:18 am
there's starion and EX1800 and EX2000 lancer gearboxes that will bolt up to the SOHC 4G63. i think some of the early L200 gearboxes might have as well but i'm not completely sure. if you were going to use the DOHC engine (out of VR4's and maybe eclipses? we don't get them over here. evo engines are no good though because they don't have suitable mounting points as they mount from the gearbox) then later L200 gearboxes are the way to go, if you want something with better ratio's then all of the above mentioned gearbox internal's will go straight in to an L200 gearbox
L200 = ute or minitruck
not sure if you got the early lancers over there but doing a search on the net would find them easy enough
and i think starions were released under a different name in america but can't remember what
cheers
Matt
project 1: TA23 Celica
project 2: 1981 EX Lancer, in the midst of a 4G63T conversion, engine, gearbox, disc brake diff, 2 piece driveshaft, loom all in, just got to finish wiring and fuel system
PostPosted: Thu Jun 24, 2004 4:23 pm
Starions were Chrysler Conquests or something.
PostPosted: Thu Jun 24, 2004 5:52 pm
Shove the Starion/Starquest guts into a Mighty Max Tranny shell.
http://www.dentsport.com
Geoff
89 Colt Turbo
92 GVR4 254/1000 Kensington Gray
PostPosted: Fri Jun 25, 2004 11:10 pm
mighty max??? if this is the small ute (minitruck) like the L200 i've got a mate over here in nz with an 84 model with a VR4 turbo motor in it and a fair bit of aftermarket work.
its run a 13.9 on 18's with not much traction. not bad for a daily driver
cheers
Matt
PostPosted: Sat Jun 26, 2004 12:07 am
4g61t Delinquent
hell id like to shove a 6G72T into my dads mighty max :twisted:
I own a CSM.
PostPosted: Sun Jun 27, 2004 6:24 am
Yeah rxtoy!!! That's the one!!! There's a guy over here in the states.
On www.galantvr4.org, his name is... :twisted: "bimmubishi" He did a 4G63 swap into a 4 door BMW 325I !!! The Starion gearing is perfect, but the gearbox doesn't line up 100%. So what he did was he took the Starion internals and inserted them into the Mighty Max box. Both theose trannys are very similar on the inside/outside!!!!
keyword........ Dent sport garage
Geoff
89 Colt Turbo
PostPosted: Sun Jun 27, 2004 7:28 am
Geoff
89 Colt Turbo
