It is currently Thu Oct 30, 2025 8:00 am
 Post subject: coil and suspention Q's
PostPosted: Thu Apr 29, 2004 5:07 pm
on a 8v 4g15, is there any reason i would have a hard time with an aftermarket coil, like a blaster
and where is a good place to get a replacement strut pivot
RX-7 Fanatic
PostPosted: Wed May 12, 2004 4:37 pm
I guess what you are saying is that you have the distributor coming out the back of the head toward the firewall? If this is the case and you have a separate ignition coil, you have many options as to what you can do.
I suggest finding whatever coil you feel comfortable with and slapping it on with a better set of secondary wires (plug wires). This shouldn't foul anything up for the computer as far as I know.
One question for the other guys out there though.
Has anyone tripped a CEL (Check Engine Light) after changing to a better coil? Just curious, I've never swapped on this particular application before. My setup is a 12V coil in distributor.
As for the strut pivot, mine were swapped as a matter of the safety check, but any parts warehouse or even the dealer should have this stuff for you.
PostPosted: Wed May 12, 2004 9:33 pm
okay
but i still cant find the mount
should i get a mirage one?
RX-7 Fanatic
