It is currently Mon Nov 03, 2025 1:55 pm
 Post subject: Tach Question (other)
PostPosted: Tue Apr 20, 2004 4:03 pm
I'm new here and I found this site after looking around for information on the engine in my Summit. My question is basicly, "Does anyone have a clue why my tach won't work?", The positive is hooked into the cigarette lighter, negative is a chassis ground, and the pickup is at the 2 wire thing by the intake (which I've seen someone else do in another tach post). The light comes on in the tach when the dash lights/headlights are turned on (the wire is hooked to the cigarette lighter light) and I just re-checked the ground/power today and it's all good, even the 12v pulse@#1 cylinder coming off the 2 wire thing is good, it's set to 4 cylinder on the back also, anyone have a clue?
PostPosted: Tue Apr 20, 2004 11:25 pm
Bad tach?
Witty Signature Goes Here!
PostPosted: Wed Apr 21, 2004 4:10 am
i heard something about mechanical tachs a while back...but i dont think yours is...
PostPosted: Wed Apr 21, 2004 1:33 pm
ask normsummit he put in a tach in his c50 summit(i have seen it)
1983 Honda VF750F
1986 Chevrolet C-10 305
1990 Chevrolet Corvette L98
1996 GMC Suburban 454
1999 Volvo S70 AWD L.P.T
PostPosted: Wed Apr 21, 2004 11:06 pm
4g61t Delinquent
now what about your tach signal wire? did you even hook it up?
-Paul
I own a CSM.
PostPosted: Thu Apr 22, 2004 1:21 am
-Paul
I don't mean to steal anyone else's picture but it's hooked up exactly like this:
http://www.ce.rit.edu/~mezz/gallery/ran ... ach_hookup
When I tested (using +/- battery and the line it's hooked up to at the moment) it before installing, it worked fine.
::edited by paul to put a link to the picture instead of a img tag::
PostPosted: Sat Apr 24, 2004 11:20 pm
It's been almost 3 days and no one has a clue?
PostPosted: Sun Apr 25, 2004 2:00 am
4g61t Delinquent
im stumped.....it shoul work....its been awhile since i had my tach in my car before i swapped in the factory tach cluster :-?
I own a CSM.
PostPosted: Tue Apr 27, 2004 8:20 pm
If anyone has a cluster w/tach I would be grateful if I could get it (as long as it isn't hundreds of dollars). I always found that strange, it's a manual from the factory and there's no tach.
PostPosted: Wed Apr 28, 2004 10:00 am
Nobody Important
did you try to grab the signal from the other side of the tach filter?
it could have gone bad.
PostPosted: Wed Apr 28, 2004 10:38 am
on my 4g15 i tried the tach wire that sould be right but it didn;t work.. try the other wire off the dist.one by one till you find it.. thats how i did it wont hurt anything while doin it
http://www.clubgp.com/newforum/upfiles/ ... d93156.gif
PostPosted: Fri Apr 30, 2004 6:18 pm
What wire off the distributer? I don't see any other wires by my dist. except for one that I looked up to be a ground. It's round with 4 connections (for the plugs) and one post type thing that has a rubber cover over it. I haven't seen any other kinds of wires in my service manual either, if there is, please let me know which one, I really want to get this thing working. It's so annoying to have it there and know it's hooked up but it's not working, like it's mocking me. :( lol
PostPosted: Fri Apr 30, 2004 7:15 pm
Get signal wire at the ecu :)
Worked justfine for me!
PostPosted: Mon May 03, 2004 4:22 pm
Could you post a picture of it so I can see where to hook it up? Also, are you using the same computer that would be in my 1991 summit with the 12v 4g15?
 Post subject: Blah
PostPosted: Mon May 03, 2004 10:59 pm
i had mine hooked up to my dist. it was an orange wire that i used(only one i got a sig. from), but after talking to berserko, he told me which wire to use.
MyRaceCarPics
MyWebSite
  • 2.0 dohc n/a swap
Users browsing this forum: No registered users and 33 guests
