It is currently Mon May 06, 2024 10:34 am
PostPosted: Fri Oct 24, 2003 3:43 pm
Please reply here with the known working suspension upgrades for the CSM.
Also, feel free to share your thoughts and opinions about the parts and their installation.
PostPosted: Fri Oct 24, 2003 9:59 pm
4g61t Delinquent
whiteline in austrailia has an extensive line for our cars :)
I own a CSM.
PostPosted: Fri Oct 24, 2003 11:40 pm
BANNED FOR FRAUD
I don't suppose Whiteline makes coilovers for our car? You need to post this extensive line.
Jason Veraldi
Scammer
PostPosted: Sat Oct 25, 2003 4:16 am
4g61t Delinquent
BMR68Z H/duty swaybar-rear Blade adjust. 220.00
79118 WL h/duty coil spring - pair 145.45
70082 WL h/duty coil spring - pair 145.45
KPR013 Panhard rod kit-adjustable 240.00
KCA323 Front lower control arm-rear caster adj. 47.64
KCA412 Front Camber adj bolt kit-12mm 71.82
KSB556 Front Strut tower brace 180.91
We can also supply the following bushes:
CA, CB Sedan 9/88 - 9/92
F Control Arm Lower - Front Bush SPF1160K 1 4B,2T
F Control Arm Lower - Rear Bush Refer to KCA323
F Sway Bar Link Bush Kit SPF2092BK 1 8B
R Panhard Rod Bush Kit SPF427K 2 1B,1T
R Sway Bar Link Bush Kit SPF2092BK 1 8B
I own a CSM.
PostPosted: Wed Nov 05, 2003 5:51 pm
Not to sure if I am to post this here...feel free to delete or move moderator.
honda hunter I dont surpose you know if the make components for the rear of a 4wd lancer? (the rear struts are 2"shorter due to solid diff) maybe like your 4wd DSM's in the states ???. Damm hard car to find after market parts for
AWD cyborg sedan
PostPosted: Thu Nov 06, 2003 7:55 am
What you describes sound EXACTLY like a 4wd DSM their strut body is 2" shorter than the colt....
PostPosted: Fri Nov 07, 2003 12:21 am
Might you be referring the 4wd Lancer wagons?
Witty Signature Goes Here!
PostPosted: Sat Nov 15, 2003 12:45 am
no not a wagon more like this....
http://www.eterna22.orcon.net.nz/
think you call them summits? in the states. It's a jap import. The front setup matches the 2wd, its the rear thats the problem. They don't use independant rear end like the VR4, its a solid diff more like old school rear wheel drive car. They use the same rear spring as the 2wd. The strut lenght below spring perch is about 2" shorter as it mounts on the top of the diff. I'll try and get OEM part number and maybe some who know's dsm's could maybe see if it matches up??? :wink:
cheers for the pic's eterna22 :D
AWD cyborg sedan
PostPosted: Sun Nov 16, 2003 4:09 am
Get a pic of the under side of the car and we can compare them to what our DSM's look like and can say for certain.
PostPosted: Mon Nov 17, 2003 7:09 pm
DSMs use a solid rear axle?? :o
PostPosted: Mon Apr 26, 2004 5:14 pm
Weitec (Daughter from KW Germany) produces a Kit with Coilovers+Shocks for CSM.i bought one for my 4G15,it has a very very good handling and the car drops 40mm.They use shortened Gas Shocks.
Lancer C68 4G67t
Eclipse D22 4G63 Cyclone
Eclipse D27 E316g,too much to List here.
Galant EA0 V6-24V
PostPosted: Tue Apr 27, 2004 12:28 am
4g61t Delinquent
B+G makes springs for our cars also. i bought them from MMRUSA.com
-Paul
I own a CSM.
PostPosted: Tue Apr 27, 2004 3:53 am
The FWD DSMs do use a solid rear axle...my 92 C50 does too. Panhard rod is opposite though. I'll measure tomorrow...and take a couple pics. Hopefully that will help clear this up?
-Kev
Cheap, Fast, Reliable......you can only pick <b>TWO</b>.
PostPosted: Wed Jun 30, 2004 12:26 am
just put in 1g fwd springs [w/ csm struts] in the front tonite. much better road feel and significantly less sway. i can verify that they do lower the car [just the front in this case] 3/8ths to 1/2 an inch.
strongly recommended for the price.
...will post on awd rears [gives closer f/r spring rates] when i get them in.
edit: got the rears on, and the car feels 1.235 million times better than it did. they aren't what i would want for racing, but they combat body roll, brake dive, and acceleration squat MUCH better than the stock springs did. nice on the terrible denver roads, too.
for the ~$25 the springs cost me: A
1g smic, 2.5" turboback, 1g exhaust cam, abs intake, 13g turbo, mbc, vdo boost gauge, greddy egt
Last edited by thehelldonkey on Tue Mar 15, 2005 11:46 pm, edited 1 time in total.
PostPosted: Wed Jun 30, 2004 12:03 pm
eclipse rear braces are a direct replacement.
PI do lowering springs.
im also wondering if evo 1 suspention will fit a colt as i think it might :-? if so EVO COIL OVERS!! :P
also the eclipse front brace will fit with new base cups made (fabricated) :)
playing with the same colt since 2002 and still going.....
