It is currently Mon Oct 27, 2025 12:29 pm
PostPosted: Tue Mar 30, 2004 10:28 pm
How exactly do i check the TPS sensor and if it's operation properly. I have the proper tools to do it........ but Im not sure where it's located. Just want to check all these things to see whats causing my RPM drops.... It still may be a vacuum leak......but I'd check this first since I have the tools.
http://www.angelfire.com/oz/plymouthcolt/index.htm
1990 Plymouth Colt GL
4g15
_______________________
Szymon Zmijewski
Sierrazulu85@Aol.com
PostPosted: Wed Mar 31, 2004 10:12 am
The TPS is located just next to the butterfly. It is black or brown/black w/ a plug from which 3 wires go away.
While it's not the officiall method for checking the TPS, this one worked perfectly for me, because the official method won't tell you if the TPS has intermittand contact issues:
To check a TPS, use an analog ohm meter (you know, those w/ a needle rather than LCD) and check the resistance while having someone depressing tha throttle slowly. The resistance should change accordingly to the throttle movement. Any large needle deflections mean the TPS is partially bad.
Edit: IIRC you should measure resistance between pins 1 and 2. Those are the two just next to each other.
Got rabies?
PostPosted: Wed Mar 31, 2004 10:50 am
that doesn't exactly tell me where it's located...... Butterfly? Let me know.... haha Thanks!
4g15
Szymon Zmijewski
PostPosted: Wed Mar 31, 2004 10:56 am
Hrm I gotta find a pic then...
Got rabies?
PostPosted: Wed Mar 31, 2004 10:58 am
I'll foot this next part Eth, the TPS is located on the side of the throttle body, first piece of metal you run into after the rubber hose running from your air filter canister....
Click here ..... for spec
http://www.4g61t.com/forum/viewtopic.ph ... tps+adjust
Hey Ethereal, you got the old pics with the guy showing the pin position and all that, think it was vfaq stuff?
PostPosted: Wed Mar 31, 2004 1:04 pm
I tested my TPS and the ohm meter read 4.5 ohms when the throttle was closed. I then slowly depressed the throttle and the ohm's stayed the same. I also had 5 volts to the TPS (The cable coming into the TPS.) Does this mean the TPS is good or bad? Does it need any adjusting? Thanks!
4g15
Szymon Zmijewski
PostPosted: Wed Mar 31, 2004 3:41 pm
Szymon, looks like you got the wrong wires. Resistance should change when the throttle is moved. Maybe it was wires 1 & 3 or something. :-?
Tim, IIRC it was indeed on VFAQ.com.
Got rabies?
PostPosted: Wed Mar 31, 2004 3:43 pm
I'll check it out again. I'll let you know what is going on. If you can post a picture, It'll be great.......to know where it is exactly.
4g15
Szymon Zmijewski
PostPosted: Wed Mar 31, 2004 3:55 pm
Hey try this: http://members.shaw.ca/dsm.1000q/Engineprimer/tps.htm
Got rabies?
 Post subject: Hyundai Service Manual
PostPosted: Wed Mar 31, 2004 4:06 pm
Instructions for testing TPS and harness.
http://www.hmaservice.com/webtech/default.asp
I selected a 92 Excel, 1.5L, then navigated into the Fuel System section. Do a search for throttle position sensor, and you'll find the procedures for testing.
PostPosted: Wed Mar 31, 2004 4:54 pm
Crackerman said "set it to 1.1 ohms at closed throttle(witha slight amount of slack in throttle cable, so cable isn't holding throttle open) using a mulitimeter"
This quote is from the other post (with the link)
My ohms are at .9. Now, do you think this affects the RPM's this much. I could set that so it'll be 1.1 but....... might it make a difference and won't make these RPM's drop so drastically when switching into gear? Let me know, and tell me if I should set them to 1.1 ohms from this .9 ohms that i have.
4g15
Szymon Zmijewski
PostPosted: Wed Mar 31, 2004 6:13 pm
.2 of an ohm I believe should be fine probably just meter being out of calibration (either yours or who ever did the reading the first time)
PostPosted: Thu Apr 01, 2004 7:59 am
Measure the output voltage w/ ignition on and engine not running. W/ closed throttle, it should be 0.48 - 0.52 Volts.
Got rabies?
