It is currently Sat Apr 27, 2024 5:51 pm
PostPosted: Sat Mar 20, 2004 3:03 pm
there was 3 plug on the ecu 1-[+amp g] 2-[-amp g] 3-[-amp h]
duno if it's lookin like the 37's but maybe this will help you telling me ?
That sounds right but I believe the 63 stuff won't work too well the Injectors are 240cc way too big for the 4g15 where the 4g37 are only 210cc before you start this project I strongly recommened having access to a datalogging device before you start messing with your fuel and so forth...
PostPosted: Sat Mar 20, 2004 3:40 pm
Dan, try comparing your 63 ECU pinout w/ a 4G15 one. I assume you still have the 63 harness around to compare. Connectorwise, even the DOHC ECUs will fit, although they don't work.
I agree w/ Berserko about those 240 ccm injectors. Go for the 4G37 stuff, except you want to go turbo w/ your 15, then I'd take the 4G63 stuff as it can easily handle up to 150 HP.
Got rabies?
PostPosted: Sun Mar 21, 2004 1:09 pm
too bad i know a guy who have a 4g63t for sale ckrank shaft balancer or somthing like that is broke but im interested cuz im gona rebuilt it slowly and i'll ride the stock 4g15 until it's done or if i can find some cheap injectors from a 4g37 maybe i'll try it with the tb ecu and maf of the 4g63 sohc do you think i's a good idea ?
PostPosted: Sun Mar 21, 2004 1:20 pm
take the 4g63 sohc pistons, shave'em 3mm like i did, it's like having 2g pistons...but cheaper.
PostPosted: Sun Mar 21, 2004 1:49 pm
Colt-r, are you sure it's a good idea to use NA pistons in a turbo setup?
Got rabies?
PostPosted: Sun Mar 21, 2004 1:58 pm
Well you could cet maybe 10psi out of them because their not forged...
PostPosted: Sun Mar 21, 2004 2:25 pm
That was exactly what I was thinking.
Got rabies?
PostPosted: Mon Mar 22, 2004 6:08 pm
what if i only put my 63 sohc's tb and maf on my 4g15 ???
PostPosted: Mon Mar 22, 2004 7:01 pm
The TB is fine... but the MAF will really lean out the car I did it for several months it was great on the gas bill but it made the 4g15 even a more extreme econo box 0-60 in about 45 minutes.... TB helps throttle response though....
PostPosted: Tue Mar 23, 2004 10:18 pm
ok thx i'll put my 50mm tb soon will it change something if put the the 4g63 sohc ecu
PostPosted: Tue Mar 23, 2004 10:38 pm
Yes because its mapped out for the wrong injectors.... You don't want to do that
PostPosted: Mon Apr 21, 2014 8:27 pm
I cant believe this thread is 10 years old anyway has anybody actually ran all of the 4g37 components. I have the throttle body and injectors I still need the maf and ecu which I am getting either on the 1st or sometime next month but I was wondering if its even worth it to continue with these upgrades. That is if people are still following this thread :prayer:
1996 Honda civic lx
1994 Ford Ranger
1991 Dodge colt 4G15
PostPosted: Mon Apr 21, 2014 8:34 pm
I ran all those parts.
My internal thought process once everything was installed, told me that the timing curve was really different between the two ECU's.
I was not a fan.
I have not used the 4g63 ECU with any sort of piggyback though. 4g37 Sonata setup, yes.
PostPosted: Mon Apr 21, 2014 10:10 pm
i ran them for a few years, up until i killed the 1.5. i liked it, seemed to give a bit more grunt at the bottom, not much, but enough to notice. mileage was the same as with the 1.5 ECU/MAF/etc. if you're looking to get a bit more out of your 1.5 for not much cash, it's worth it. if you're planning an engine swap somewhere down the line, forget it and aim for the swap.
PostPosted: Tue Apr 22, 2014 5:43 pm
so what would happen if I just swapped in the 210cc injectors in my 4g15 and waited to do everything else later.. Would it give it more fuel and fire better or would I just choke the crap out of it??
1996 Honda civic lx
1994 Ford Ranger
