It is currently Sun May 05, 2024 7:35 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page 1 2 3 4 Next
 Post subject: Clutches...
PostPosted: Wed Feb 18, 2004 10:05 pm
Does anyone have any informative reviews of good clutch combo's?
I have a new clutch right now, but I dont have a good tranny so I can't really rate the clutch very well when it barely shifts right now... :lol:
PostPosted: Wed Feb 18, 2004 11:17 pm
I have a centerforce dual friction, pressure plate and disc, and it works great, grabs nice, and the pedal is as light as stock.
good clutch,
Jimmy
1997 Eagle Talon TSi - 11.3 @ 126MPH
1989 Colt Turbo - 198WHP 202 Torque - RIP
1991 Colt Turbo Conversion Targa Rally Car - Work in Progress
PostPosted: Thu Feb 19, 2004 2:58 pm
is your centerforce using a DSM 2.0 flywheel or the 1.6 flywheel?
PostPosted: Mon Feb 23, 2004 11:34 am
Banned for being a dick
Elvis has left the building
PostPosted: Mon Feb 23, 2004 10:34 pm
Ive got a 2.0L Turbo dsm FWD flywheel, with a galant vr4 h/d daikin clutch kit. 5 puck brass button sprung centre.
It is a little heavy on the left leg in traffic, but grips extremly well... it is a bit of a pain in traffic though as it shudders alot
Part number R320nhdb (Daikin part number)
Mike
Member #31
PostPosted: Mon Feb 23, 2004 10:51 pm
I ordered the 2.0 FWD Turbo flywheel, and the 3kgt clutch kit, I'll let everyone know, I'm just worried about the splines.
LSD, 1g flywheel/clutch.
Now I ran out of fuel!!
PostPosted: Fri Feb 27, 2004 5:02 pm
1.6 flywheel
Jimmy
PostPosted: Fri Feb 27, 2004 6:05 pm
I have had good luck with a used 2100# "RPS Turbo" pressure plate / OEM AWD disc combo. It took all my small 16G 309 HP 4G63 could give it. The previous 1400# OEM AWD clutch on a FWD 2.0 flywheel wouldn't hold though. A couple observations I noticed were (1) a significant increase in pressure on the "Turbo" clutch and (2) for complete disengagement the pedal has to be against the floor [it is adjusted properly] i.e. the pedal has to travel further on the Turbo clutch. I don't know if this is normal. This is especially necessary during a high RPM shift. I also had to put a 1/8" washer on the throwout arm pivot bolt to position the arm correctly.
PostPosted: Tue Aug 15, 2006 11:52 am
I am using a 2600ACT pressure plate and a stock AWD disc from a 1st Gen. Combo works very well for daily driving, but I would say go with a 2100 if your not planning on running more then 300HP.
2600 does get tiring after a while.
PostPosted: Thu Feb 01, 2007 8:12 am
Definately agree. I was running a 2600 in my 4g63 on stock flywheel. The stock clutch fork just couldn't handle this heavy of a pressure plate (bent and warped). I switched over to a ACT AWD flywheel and 2100. Much better.
If you aren't going to make mega power, don't put a mega clutch in.
Scott
PostPosted: Thu Feb 01, 2007 9:24 am
I had a 2.0 fwd aluminum flywheel, with what spec called a stage 3 clutch. I stalled it 3 times the first day backing it out of the garage, I was not use to the light flywheel, plus it grabs really hard. I did like it after getting use to it.
Worked fine until I blew the tranny up, took it all apart and half the springs were gone out of the disc. Spec admitted that they had a design flaw with it, and sent me a new updated disc on warranty. The metal that holds the springs in is now about twice as thick as before.
- Works in da bush
PostPosted: Thu Feb 01, 2007 9:28 am
ACT 2100 with Fidenza FWD flywheel, a little heavier pedal than stock, but holds nice, where the Centerforce D/F slipped after 5000 klicks.
PostPosted: Mon Jan 14, 2008 10:10 pm
I have a Clutchmasters Stage 4 four puck ceramic clutch and the stock 1.6 flywheel. Works perfectly.
PostPosted: Mon Jan 14, 2008 11:58 pm
I would have to recommend against centerforce very strongly! Read anywhere on tuners and you'll see why. They don't hold sh*t for power, they are good for other cars but not DSMs.
I've ran a Southbend Clutch stage 2 clutch, which is their kevlar disc clutch kit, with a Fidanza on my old GS-T. It held whatever I threw at it and I loved the grab it had.
On my colt, I'm going to be running a stock clutch with a fidanza flywheel. I'll let you know how it feels. I'll be around 200whp to start.
PostPosted: Tue Jan 15, 2008 3:48 pm
I'm interested in the ACT pressure plates. Does anyone know how much power the 2100 can hold? Thanks.
