It is currently Sat Jun 15, 2024 11:32 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page 1 2 Next
PostPosted: Tue Jan 13, 2004 7:56 pm
Hey guys, I just sold a brake master cylinder off of a 95 3000GT VR-4 and I noticed that the lines and bolt spread looked the same as the one on my Colt....so I went to see how it would fit......The thing friggin bolted right up, lines, and resevoir. you go from a 7/8" brake master to a 1-1/16" with no modification!!!!!!!
and I have a bunch of these here in stock $25 each plus a few dollars for shipping
Just as a comparison, I just spent $200 on a 1-1/16" brake master from a 300zx for a Nissan 240sx drift car I have been building for a customer.
If it don't make power it's not worth the hour!!!!!
PostPosted: Tue Jan 13, 2004 8:02 pm
Miragetec Yes I have been running one of these for a year this is a known upgrade but the issue is they suck BAD on a mirage because ther booster is no where near as powerful as it should be for that it has like a 3.7:1 boost ratio where the 3000GT is 7:1 how much do you have the boosters for?
PostPosted: Tue Jan 13, 2004 8:12 pm
so are the non vr-4 master cyl's diffrent?
PostPosted: Tue Jan 13, 2004 8:16 pm
ABS are 1 1/16 and Non ABS are 1 Inch...
PostPosted: Wed Jan 14, 2004 1:26 pm
I have a bunch of boosters also, I need to pull one off of a colt to see if the 3000 booster will bolt up.....or maybe you already know :D
I would sell you guys the booster with the master for $75 plus some shipping.
I bet your face would hit the windshield after you put this on with some stainless lines!!! I can't wait :D
PostPosted: Wed Jan 14, 2004 1:28 pm
Nobody Important
I'm sure my stock 1.5l solid rotors would just LOVE having that much force on them ;)
 Post subject: booster bolt pattern
PostPosted: Wed Jan 14, 2004 1:36 pm
Yes, the booster uses the same bolt pattern and the same aluminum spacer between the booster and the firewall. I forget what the diameter of the 3kgt booster is though? I remember one car used a really large diam booster that wouldnt quite fit into a colt? It was like 13" or something?
Chris
PostPosted: Wed Jan 14, 2004 1:43 pm
Some later year Galants w/ 180 or so HP seem to have the same booster as the Colt GTi (which is, of course, a CSM). Dunno for the 3KGT. :(
Got rabies?
PostPosted: Wed Jan 14, 2004 2:34 pm
Ok here we go, I measured a stock Colt booster and a 3000GT VR-4 booster WITH ABS
Colt booster is 8-3/4" in diameter and 3-3/8" thick from the surface that the master bolts on to the rear surface where the alum. spacer sits
3000GT booster is 9-1/4" in diameter and 4" thick measured from the same points as the Colt booster
So IT WILL FIT!! :D
I am going to put that set up on the AWD car this weekend
PostPosted: Wed Jan 14, 2004 2:53 pm
i would be intrested in buying this setup from you for that quote of $75.. let me know what goes down
PostPosted: Wed Jan 14, 2004 3:04 pm
Sure, let me get that thing all bolted up just to make sure, like I posted before I have a bunch of these things in stock so I will save one for you.
Thanks
PostPosted: Wed Jan 14, 2004 3:18 pm
cool, i was going to suggest the same thing... as long as it works for you then i'd definately be down for that combo..
PostPosted: Wed Jan 14, 2004 6:20 pm
I'm interested.
PostPosted: Wed Jan 14, 2004 7:24 pm
Miragetec so would it be $50 for the booster? if I only needed that? I have the 1 1/16 MC already without the booster its a might bit useless...
PostPosted: Wed Jan 14, 2004 7:49 pm
Yep, $50 for the booster
