It is currently Tue May 21, 2024 10:19 pm
Post new topic  Reply to topic  [ 63 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Dec 04, 2003 2:28 pm
Probably you have an A/F ration of 14:1 or so @ WOT instead of 13.0:1. :o I'd really like to try the 4G63 SOHC. The injectors are good for almost 150HP @ 70% duty cycle. Also, driving should be somewhat smoother. However, the spark & fuel maps are probably totally wrong. The 4G37 should be better suited. But hey, how about a G4CS MAF on a 4G37 ECU? Should work somewhat better I think.
Got rabies?
PostPosted: Thu Dec 04, 2003 7:41 pm
I'm not leaning to motor my O2 voltage is right on par .92v or so... Well if I can find a some ECUs that are eprom it can all be fixed we know how fuel and timing and all that is done by ECU it is within our grasp... :)
PostPosted: Thu Dec 04, 2003 8:40 pm
Seems to me that would indicate a rich condition rather than lean. .92 is almost at the end of the 1v operating range.
Witty Signature Goes Here!
PostPosted: Thu Dec 04, 2003 9:43 pm
From what I read during a WOT run .9-.92 is exactly where you want to tune your car for...
PostPosted: Fri Dec 05, 2003 7:03 am
Yep. I've done wrong w/ that 14:1 crap. The O2 sensor can read from lambda 0.9 to 1.05 (A/F 13.23:1 to 15.44). Maybe the car was running w/ lambda=0.85 (A/F 12.5, mixture is getting somewhat hard to ignite below that), as Jason once suggested. Could be it is now running @ 13.3 or something just on the edge of the sensor being able to measure.
Got rabies?
PostPosted: Sun Dec 07, 2003 1:43 pm
Hey guys, if the 4G63 SOHC stuff works, this may be the perfect ECU upgrades for turborized 4G15s. I came up w/ this when calculating the possible power from the 240ccm injectors and wondering what that much power could be used for... and then I remembered Ricehunter's 4G15T manifold. :D
Got rabies?
PostPosted: Sun Dec 07, 2003 5:30 pm
I installed the injectors and maf from a 1.8l sohc today! There were idle issues at first but after comparing MAF's i found a solution. I plugged the small holes in the sides of the maf and it runs fine. A little rough at first. Going to drive it for a few days so the ECU can adjust. Seems to offer more bottom end umph. This is definately a doable mod! Check out this post to see what i mean about the holes:
http://www.4g61t.com/forum/viewtopic.php?t=6523
Next is to find a ECU!
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Sun Dec 07, 2003 11:13 pm
I have one, let me know.
PostPosted: Mon Dec 08, 2003 2:50 pm
More bottom end is what every 4G15 driver is searching for! Woah this all makes Adrenaline rush through my veins! :twisted:
Got rabies?
PostPosted: Mon Dec 08, 2003 9:27 pm
I'll keep you in mind if i dont find one at work! :)
So far the only prob ive noticed is at idle it seems a little lean . However, i a few other problems to sort out that are unrelated to this mod. May run better with the 1.8l ecu. My idle has been surging, have a miss, and A/F guage reads oddly at times. Gonna check temp sensors, ISC, and swap ecu. These started before i did this mod.
Question: is there any difference between the Mitsubishi and Hyundai ECU pin outs?
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Dec 09, 2003 3:50 am
Pin outs for what? the ECU? ISC? Temp sensors?
PostPosted: Tue Dec 09, 2003 7:21 am
Sorry. :-? I meant is there any difference in the wiring leading to the ECU between a Mitsubishi and Hyundai 1.8l wiring. Also i was looking at the Ecu plugs on a 4g15 and they seem to have some different wires in different places than the Mitsubishi 1.8l
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue Dec 09, 2003 8:24 am
What 1.8 were you looking at? The 4g67 the 4g37? the 4g93? The only one I know fits is the 4g37 out of old talons the 1.8's from Elantras are distributorless definetly won't fit and 4g93s also do not work... 4g37 is our only option...
PostPosted: Tue Dec 09, 2003 8:30 am
Thanx Berserko! Thats what i needed to know! I'm going to look around work today for an ecu.
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Thu Dec 11, 2003 8:26 pm
One thing I didn't think about on the G4CSmotor is the timing belt mount as its not the DOHC cam it may or may not fit i'm sure if it didn't it would be a very minor mod for anyone considering to do it it would have to be thought about at least. I almost want to buy another Colt for Cheap and try this simple swap and see how well it works....
