It is currently Sat Apr 27, 2024 1:22 pm
PostPosted: Sun Sep 21, 2003 2:45 pm
on my deck i have two outputs. My speaker amp which i got for free (but i know it works) has the inputs, but then my sub amp has the same inputs..
how to i wire this bad boy, they both use the same inputs and i can only use one at a time. Do i need to buy some sort of spliter?
maybe a better deck would solve my problem its a crummy 35x4... maybe if i got a 55x4 mosfet my 6/9's wont distort...
any suggestions?
i have a 10' kicker and 12' MTX, maybe my buddy will give me his deck.
PostPosted: Sun Sep 21, 2003 10:16 pm
well i used a set of splitters since my old sanyo cd/cassete deck only had one amp output. my old kenwood amp had two sets of inputs to work all four channels. so thats wut i did. the big draw back i guess that using the splitters is it turns your one 2volt output into two 1volts outputs. cuts sound quality down. but hey beats the heck out of buying a new deck. if you do get a new deck wut would be best is to get one with a 4volt sub specific output and an second 2volt set of outputs
1992 Galant VR-4 810/1000
PostPosted: Mon Sep 22, 2003 6:40 am
Splitter.Or.... some amps have output jacks so you can plug another amp in as it sends the signal back out. My Legacy amp has this feature. I used to have another amp hooked to it driving the rear deck speakers. Also, If its a bridgeable amp, you can run it with the sub bridged and your L&R speakers hooked normally. I tried this for awhile too.
If it can be hooked up a certain way, i have to try it out. :wink:
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Sep 22, 2003 9:54 pm
Another idea would be to get a standalone preamp. front in, rear in, then front out, rear out, and sub out. Look into it.
Witty Signature Goes Here!
PostPosted: Wed Sep 24, 2003 6:23 pm
Goto a pawn shop you find all sorts of hot stereos in there that have 2 outputs thats what i recommend...
PostPosted: Thu Sep 25, 2003 7:44 pm
Pawn shop...yeah. Good stuff for half the price of new! :D
Or...if you live in a neighborhood with lots of crack-heads, you can get just about anything from them for $20. :wink:
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
