It is currently Tue Jun 04, 2024 9:07 am
 Post subject: low idle when cold.....
PostPosted: Wed Sep 24, 2003 6:08 pm
I have a low idle while cold that sounds like its about to stall(hasn't yet though) that pretty much goes away once the car is warm, I saw something somewhere on how to check the idle speed controller but forget where I saw that, anyone have any ideas for me to check stuff?
RIP- '92 Colt 200E, 12valve 4G15, 5spd.
'89 Colt 200E, stock 8valve 4G15, 5spd,
PostPosted: Wed Sep 24, 2003 6:16 pm
Start with http://www.vfaq.com
PostPosted: Wed Sep 24, 2003 11:18 pm
thanks, thats gunna give me some reading material for a few weeks *L* :D
PostPosted: Thu Sep 25, 2003 7:28 pm
What year is your car? On the 12 valve engines there is a screw on the throttlebody by the one that raises the idle. If your idle is set correctly, turn that screw in a bit it will raise the high idle when the AC is on and during cold starts. It adjusts the ICS motor on the throttlebody. Not sure on the older 8valve motors since they have a different throttlebody.
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Fri Sep 26, 2003 4:50 am
4g61t Delinquent
the 8v 4g15 have them also ;)
I own a CSM.
 Post subject: This sounds familiar
PostPosted: Fri Sep 26, 2003 7:27 am
Have a look at this, see what you think...
http://www.4g61t.com/forum/viewtopic.ph ... ure+sensor
PostPosted: Sun Sep 28, 2003 2:30 pm
I adjusted the other screw then played a bit with both and it idles fine now, would like to find a procedure to set these correctly though. BTW it turned out the idle speed controler is working, was going up and down causing it to come close to dying then it would pick it up which would rev it up pretty good then come back to darn near dying again, it was hunting for what it wanted but never found it *shrugs*
PostPosted: Sun Sep 28, 2003 3:00 pm
or maybe not, fired it up this morning and its still hunting, it dosn't last as long as it used to though
