It is currently Thu May 02, 2024 12:04 am
 Post subject: Dave's Summit Wagon
PostPosted: Fri Dec 23, 2022 9:47 pm
Well after all these years, I've determined I think my ideal daily driver is a "tall wagon" or "mini minivan", ultimately with a 2.3 turbo, manual and AWD. Not a perfect place to start given that goal, but it was hard to pass up for the price: I picked up a 1994 FWD auto Summit wagon (2.4 SOHC) about 5 months ago. It's in excellent condition in terms of being unmolested and bone stock, but is was extremely nasty, including cat pee and rain ingress. Although I like the several Facebook groups for these cars and similar Mitsubishi platforms, I still like the forums better for this kind of stuff (thanks for keeping this up, Tim). So I thought I would post my plans and progress thus far.
Since I had a spare FWD tranny sitting around, I took the Summit off the road started the manual swap. I've built a clutch pedal assembly and shifter assembly with parts from a 1991 Galant. Also had to fab up roll stop mounts since this is a 7-bolt and the tranny is off a 6-bolt. There are about 6 specific areas to do this: flywheel/clutch, tranny mounts, shifter assembly, cables/tranny interface, hydraulic master/slave system, and pedal assembly.
Currenly the transmission swap is done, but I pulled out the entire interior (except the evaporator) starting from the firewall and am in the process of reassembling. Since I had to remove the interior to do a really deep clean, I decided I would go the extra step and put sound deadening insulation in the interior. I started with the firewall, and man does it suck. I hope it's worth it.
Also did the typical water pump/timing & balance shaft belts, bearings & accessory belts. Spark plugs too. It had a leaking cam seal, so I replaced that. I changed the oil & filter as well. Currently, I've disassembled the center HVAC plenum with the heater core and am cleaning it up (with Clorox wipes) piece by piece and reassembling.
I had an old set of 15" Galant aluminum wheels sitting around that were a bit rough. I had them media blasted and powdercoated white. Pics to come.
Dave Peter
-1994 Eagle Summit LX Wagon FWD, Manual Swap
-1989 Mirage Turbo
-1990 Plymouth Colt Vista Wagon AWD
-1992 Galant VR-4 (sold)
Can't polish a turd.
 Post subject: Re: Dave's Summit Wagon
PostPosted: Fri Dec 23, 2022 10:04 pm
As puchased:
With my 15" Galant VR-4 wheels & snow tires:
New ball joints, sway bar endlinks and polyurethane swaybar bushings:
White wheels mounted:
Firewall with insulation, left:
Firewall with insulation, right:
Let me know if there are specific photos anyone wants to see.
Dave Peter
-1989 Mirage Turbo
PostPosted: Sat Dec 24, 2022 1:28 pm
lookin good.. keep at it and that sound deading stuff should do great.. wish I would of did mine when it was apart.
PostPosted: Thu Jan 05, 2023 3:09 pm
Just seeing this. I'm on my 5th wagon now. This time a 93 Expo LRV with a 4G93, fwd manual. They are awesome daily drivers for sure. Please keep us updated on the progress.
PostPosted: Thu Jan 05, 2023 9:35 pm
Thanks for the reply, Chris. I put it together enough to start it on Tuesday and learned the 7 bolt starter isn't long enough to engage the flywheel. Fortunately, I had a 6 bolt starter on hand, and swapped it, and it started right up. I have the (spotless) heater core plenum installed and mated correctly to the evaporator plenum. Now to assemble the blower motor plenum (it's now spotless too) and move forward from there.
I did drive it in the neighborhood last night just to see how it feels. Pedal placement may need to be addressed, but I'll try to resolve with some pedal pads first before I resort to bending the pedal arms. I still need to install cotter pins in the drive axles and install the right rear wheel spacer (left rear is on). I don't like the look of the rear wheels being narrower than the fronts.
To lower it, I want to use Koni yellows for the front, which is proving difficult since the inserts are discontinued and the front EVO struts seem to be as well. The 2g Koni's will work in the rear (already bought a set), but I need to see whether to weld on an extended mounting point or not.
I'll get it out of the garage and snap and upload some photos by the end of the weekend. BTW, the 2.4 block is still here with your name on it if you ever get this far west, or I ever get your way.
Dave Peter
-1989 Mirage Turbo
PostPosted: Sat Jan 07, 2023 11:36 am
Here's a few pics:
Dave Peter
-1989 Mirage Turbo
PostPosted: Tue Jan 31, 2023 5:25 pm
what are your thoughts about parting ways with the vista wagon?
PostPosted: Tue Jan 31, 2023 5:59 pm
I’m not interested in selling it at this point in time.
Dave Peter
-1989 Mirage Turbo
PostPosted: Sun Mar 12, 2023 6:14 pm
Time for an update. Bellow is a list of what I've done. I'm really stoked because I just now got the cruise control working. The path was arduous (map out and understand 26 conductors into/out of the controller), but the solution was quite simple (cut three wires). Recall, I swapped the automatic transmission for a manual, so the wiring is different.
COMPLETED:
ENGINE
replace timing belt
replace tensioner
replace idler pulley
replace tensioner pulley
replace balance shaft belt
replace balance shaft belt tensioner pulley
replace water pump
replace cam seal
replace spark plugs
STEERING/SUSPENSION
have new tires installed
replace ball joints
replace sway bar end links
replace swaybar bushings with polyurethane
install camber bolts
replace tie rod ends
replace inner tie rods
replace tie rod boots
seal rack
align front end
install wheel spacers
center the sway bar
TRASMISSION SWAP
install transmission
get cruise control working
install braided ss clutch line
install mounting bracket to transmission
fabricate shifter base
adjust shifter/shifting
Doesn't really look much different, but here's a couple of pics I just took:
Much more on the "to do" list...
Dave Peter
-1989 Mirage Turbo
PostPosted: Mon Mar 13, 2023 6:15 pm
I also meant to add that the stock 2.4 non-turbo engine and the short gears of the N/A Galant transmission is adequate, even peppy. On paper it's 136 horsepower and 145 pound feet of torque, but I'm not unhappy with the acceleration. I do plan on replacing the 5th gear with one from a turbo transmission (hopefully it will fit) so I have a good overdive for the highway. With the current 5th gear, at 80mph, the engine is spinning >4k rpm. I'll do that when I replace the 2nd and 3rd gear synchros. So as of right meow, no plan to put a turbo under the hood.
Dave Peter
-1989 Mirage Turbo
PostPosted: Thu Jul 13, 2023 9:33 am
Glad to see people still come here your build with the details I love it
