It is currently Tue May 11, 2021 5:46 am
PostPosted: Fri Aug 24, 2018 10:09 pm
Planning to do belt replacement on my JDM 4G67, but the 67 never came out locally so there's no parts catalog at the dealers. The 4G63 N/A did though and I'm pretty sure I can use majority of the parts from that, but I'm not sure about the timing belt itself.
Is the timing belt on the 4G63 N/A 6 Bolt the same as the 4G67?
PostPosted: Sat Sep 15, 2018 6:32 am
Best to do a search with the car engine in question. Grab part numbers and confirm the tooth count on the timing belt.
http://mitsubishi-motors.kiev.ua/1/
https://www.mitsubishi-forums.com/59-9g ... i-asa.html
PostPosted: Sat Dec 29, 2018 9:10 am
Yes they are the same !
Lancer C68 4G67t
Eclipse D22 4G63 Cyclone
Eclipse D27 E316g,too much to List here.
Galant EA0 V6-24V
PostPosted: Sat Jan 05, 2019 6:11 pm
Must only be the 4g61 that is 2 teeth? shorter.
