It is currently Sat Jan 18, 2020 1:24 pm
PostPosted: Sun Feb 26, 2017 6:43 pm
See below:
PostPosted: Wed Aug 02, 2017 6:56 pm
administrator
The 3G 89-92 CSM Body Repair Manual is available at http://4g61t.org/archive/manuals/89%20c ... manual.pdf
Mirror of the other manuals is available at http://4g61t.org/archive/manuals/
PostPosted: Wed Aug 02, 2017 9:41 pm
I'll edit the title of this thread to reflect this. Thanks to those that offered to host the files! I cleaned up the thread so just pertinent information is contained within.
PostPosted: Sun Apr 14, 2019 9:16 am
Have recently come across some updated versions of ASA.
Updated around the April 2018 to 2019 time frame. It doesn't get any newer at this point.
This can be good if it retains all the parts numbers that exist, versus parts numbers that are NLA in the OEM parts system. If numbers disappear, that would be unusual and bad all at the same time, so keeping older copies may be good at this point.
Regardless, these are accessible via the link below - but it is hosted likely in Russia. Russia was nice enough to supply the biggest set of worldwide ASA programs that we had access to some years ago, so I am quite thankful for that.
Here is the direct page where you can make your choices on what you need to use, to sort out your car or truck or van.
http://mmc-manuals.ru/Downloads
