It is currently Tue Jun 04, 2024 2:39 am
PostPosted: Tue Mar 21, 2017 3:13 pm
Like the title says, can I run the axles on my base model with the turbo hub/brake setup? I wasn't sure if the spline was the same. Thanks in advance.
1991 Plymouth Colt - Project
PostPosted: Tue Mar 21, 2017 8:43 pm
Long way around on this response. Only the matching caliper brackets, calipers and brake rotors are different between the solid and vented rotor setups. All other suspension/knuckles and hubs stay the same at the front of the car.
PostPosted: Wed Mar 29, 2017 6:37 pm
Yes, the splines are the same.
