It is currently Fri Apr 19, 2024 9:10 am
 Post subject: Re: Swap started
PostPosted: Sat Mar 11, 2017 12:45 pm
I finally tried fitting the 1985 Proton Saga lowering springs. And they don't fit. I wonder if there is a difference in front struts between our turbo and non turbo colts.
These springs might be for non turbo struts.
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Sat Mar 11, 2017 7:27 pm
i have run 4.5in springs on perches made for 7in springs. very pleased with how it worked.
PostPosted: Sat Jun 10, 2017 7:05 pm
I've been posting on Facebook. I haven't been on here lately. But here are some updated pics. Some have been posted on Facebook.
Transmission had a input shaft seal leak. So I had it fixed and while it was at the shop, I had a BM lsd insert I bought on here over ten years ago finally installed. Also went ahead with a lightened flywheel. And a new 2100 disk. And new shifter brass bushings.
Now running a 3"GM maf.i might move the battery back up to the front. I need to clean up the power wires otherwise.
DRCOLT
PostPosted: Sat Jun 10, 2017 7:08 pm
DRCOLT
PostPosted: Sat Jun 10, 2017 7:11 pm
DRCOLT
PostPosted: Sat Jun 10, 2017 7:13 pm
And tried on some 16's that came with my 89 hatch.
DRCOLT
PostPosted: Sat Jun 10, 2017 7:47 pm
:supz: Car looks great with those wheels
PostPosted: Tue Jun 13, 2017 5:49 pm
Yes wheels look right:). Great swap! Did you get the idling sorted out?
PostPosted: Tue Jun 13, 2017 7:36 pm
Its more stable. I'm taking the car to Reza at Dynotune in Pickering this week to tune it. I'm hoping all goes well. I haven't changed the fuel pump yet. I want to see how much I can get out of the stock fuel pump. I am having a hard time understanding ecmlink. My issue is I dont have enough time to tinker with the program.
I will keep posting.
The 16's now have new rubber, Rims had to be drilled to fit front rotors without spacers.
DRCOLT
PostPosted: Wed Jun 14, 2017 12:31 pm
If the fuel pump is like the next gen 3G style, it may have sub 140 LPH capacity. Not sure what a CSM turbo 2G came stock with, but here is the reference for the bigger brother:
http://www.roadraceengineering.com/fuelpumptechtip.htm Most of the way down the page are the fuel flow rates.
PostPosted: Wed Jun 14, 2017 1:05 pm
nice info.. also to add most people dont know about this lil thing but I have a accuvolt I bought back in the 90s for my stereo.. come to find out u can also use it on your cars electric system.. what it does is takes any voltage from 12v down to 10v and converts it to a SOLID 14 or 16 volts.. so your coilpacks and fuel pump produce there best output without dropping off at higher rpms due to old/weak alt/battery..
http://www.jacobselectronics.com.au/raceaccuvolt.htm
I should start a new thread with this info..(at another time lol)
PostPosted: Mon Jun 19, 2017 9:39 pm
So it looks like it has plenty of fuel with just FIC 750s and stock fuel pump and FuelLab filter. It went in running 13psi Boost running very rich and pushed 240hp.
Turned up boost to 16-17psi and leaned out the fuel trim and managed to hit a 277.9hp. As the intercooler was getting hotter, we started to see knock with injector duty increasing to 85% @ 18psi. So boost was backed to 16ish psi.
If I want to see more HP, it was suggested to upgrade the starquest IC and not worry about the fuel yet.
I'm more than happy with the drivability now, much smoother than before and quite more peppy.
DRCOLT
PostPosted: Thu Aug 31, 2017 10:04 pm
Its been a while, but its in for paint. Pics will come soon.
DRCOLT
PostPosted: Fri Sep 29, 2017 9:18 pm
It's painted. Still need to touch up the skirts, wiper arms, window trims and moldings.
DRCOLT
PostPosted: Thu Nov 23, 2017 4:25 pm
Wow, looks awesome! will definitely have to look you up when in the GTA.
